Hi,
Is there a free download that anyone knows of that will enable me to change the files so I can play the DVD's on my player..? I have Windows Vista
Thanks..!!
Check out this thread: https://forum.videohelp.com/topic346331.html
Feed the resulting .AVS files to your favorite mpeg2 encoder and DVD maker. FAVC is a good free one.
The result looks pretty decent
vts_01_1.mpg -
There's no way of playing back HD files on a standard DVD player that I know of. There is a way of playing them back on a Blu-Ray disc player but it's complicated.
If your source format is true AVCHD, as your title suggests, understand that your resulting converted DvD will be of inferior quality.
Having said that, Soopafresh'es advice will give you something above decent and playable in DvD players.
If you have a BD player or PS3, then you can retain the higher quality AVCHD by using tools like TSMuxeR and TSRemux and burning it onto a DvD. But you would need a BD player that has the "AVCHD" logo on it.I hate VHS. I always did.
Problems editing AVCHD video?
By Benhermies in forum Newbie / General discussionsReplies: 0Last Post: 16th Jul 2011, 18:25 -
problems converting mkv to avchd
By mattybut in forum Video ConversionReplies: 3Last Post: 22nd May 2011, 00:54 -
Problems converting HD DVD to AVCHD
By fearmyrage in forum Blu-ray RippingReplies: 6Last Post: 19th Feb 2010, 19:55 -
Problems with encoding AVCHD in Vegas 8
By Animy in forum Video ConversionReplies: 5Last Post: 19th Aug 2008, 15:24 -
Nero Vision5 and problems with avchd
By gekko_video in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Apr 2008, 04:28
