Possibly a dumb newbie question but here goes. And apologies if it isn't in the right section.
I have a Sony RDR-GXD360 DVD recorder using which I have recorded to DVD-RW(video) a whole mess of home movies. But I can't seem to get my PC to copy the discs.
I have managed to get Nero Express 2 to copy the video to a disc but no audio followed it.
I'm hoping that it is just a software issue and with the right application I can continue to use the Sony box and copy the DVDs to a format I can play on other DVD boxes - got to make copies to send to Granny.
Any steers greatly appreciated.
Is it a standard dvd-video(It should be a VIDEO_TS folder with vob,ifo,bup files) or some other format?
Did you make a disc copy in nero express?
Don't you hear any audio when you play it on your computer or/and standalone dvd player? -
Thanks for the swift response.
Unfortunately I erased the DVD copy that gave video without sound. I can't recall the Nuro method so I'll try a couple of repeats this weekend.
I've checked a couple of the Sony created 'masters' and there seem to be two formats in play. One has the VIDEO_TS folder (but these won't play on my XP PC) one has a folder called DVD_RTAV and a .GROW file. -
Did you finalize the disk? I have a Maganavox DVD recorder and if I use anything but DVD+RW disks in it, I have to finalize the disk or it will not play in anything other than that recorder. For DVD+RW disks, I don't have to finalize and it plays OK and my PCs can read it.
Coincidentally, I usually record on this deck using DVD+RW disks, then do simple edits (usually I-frame cuts only) on the PC before burning to DVD+/-R.
CogoSWSDSOld ICBM Coordinates: 39 45' 0.0224" N 89 43' 1.7548" W. New coordinates: 39 47' 48.0" N 89 38' 35.7548" W.
Copying DVD movies with a Sony VRD-MC6 Multi-Function DVD Recorder.. help?
By madeyeX in forum DVD RippingReplies: 14Last Post: 17th Dec 2014, 21:36 -
finalizing dvd after image has been written
By Down1oader in forum Authoring (DVD)Replies: 3Last Post: 1st Dec 2011, 18:10 -
DVD cannot be read after written - Pls Help
By its_me in forum DVD & Blu-ray WritersReplies: 6Last Post: 11th Jun 2008, 03:25 -
Written/burned DVD-R Question
By BrokenOne in forum DVD & Blu-ray WritersReplies: 3Last Post: 22nd Apr 2008, 00:11 -
Sony DW-Q28A can't read DVD+R written on itself
By mackayr in forum DVD & Blu-ray WritersReplies: 3Last Post: 5th May 2007, 19:31
