I want to convert some avi files to mpeg2. Do I need to do anything more than select 29.9 fps in tmpgenc? thnx
If your AVI type files include the common MP3 VBR audio, watch out for sync problems from that. I usually extract the audio with something like VirtualDub or VD Mod and save the audio out as a WAV with full processing, then use that with ffmpegGUI to convert to AC3 audio. You can author both streams to DVD with a program like GUI for dvdauthor, then burn with ImgBurn to a DVD.
Or if you are looking for a easier way with less control and usually less quality, try the freeware FAVC or the payware ConvertXToDVD.
Thanks guys. Can I assume I just select 3:2 pulldown in the main video section instead of using the one in the advanced section? Just want to make certain.
redwudz, I have found that ffmpeggui is not very good for converting those files to ac3. The resulting ac3 file is actually lower in volume than the original and sometimes the program will even crash during this process if you just drag the video file directly into the encoding window. AOA Audio extractor has been a godsend in comparison. The audio quality and volume don't appear to be affected like it is with ffmpeg.
To synchronize 29,970 audio fps for 23.976 fps
By DruidCtba in forum Newbie / General discussionsReplies: 1Last Post: 27th Sep 2009, 13:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 16:23 -
Difference between 23.976 fps and 23.98 fps ???
By wasimismail in forum Authoring (VCD/SVCD)Replies: 5Last Post: 27th May 2008, 01:42 -
Converting 23.976 fps to 29.97 fps
By wasimismail in forum Video ConversionReplies: 8Last Post: 14th May 2008, 19:26 -
20 fps to 23.976 fps Questions
By Maikeru-sama in forum Video ConversionReplies: 39Last Post: 27th Aug 2007, 10:16
