I can import TEXT files as subtitles into DVD Architect just fine, but it doesn't seem to recognize anything after the first line of text. The text file looks just fine, and what DVDA does import also looks fine. The manual offers absolutely no help (big surprise).
Anyone seen this problem before and solved it?
Hi Hurricane,
Seems you try to import the text in the wrong format.
Check out this topic: https://forum.videohelp.com/topic348374.html.
For linebreaks use
, text has to be Unicode and be sure the text
is saved in Unicode. Change .txt into .sub and import it into DVDA.
Hope this'll work. -
Hi Lippy,
I saw your previous post, but that doesn't seem to work for me. I'm using SubRip, and the only way DVDA accepts the subtitle file is to rip it to TXT format, then load it into Word and save it as a Unicode text file. DVDA is happy with that but it won't display anything but the first line.
I've gotten around it for now by simply putting all the subtitles on one line, but now I'd like to puzzle this one out. If I could extract it in "DVD Architect Subtitle Script" format, I'm sure I could load it, but that's not one of the options in SubRip and the other sub files apparently are different enough to make them incompatible. -
Hi Hurricane,
The DVDA-subtitle format looks like this:
0001<Tab>00:00:01:00<Tab>00:00:02:00<Tab>This is a single line.<Hrt>
<Hrt>
0002<Tab>00:00:02:04<Tab>00:00:04:00<Tab>This is an example<Hrt>
of two lines in a subtitle<Hrt>
<Hrt>
0003<Tab>00:00:04:04<Tab>00:00:06:00<Tab>This third subtitle<Hrt>
also has two line<Hrt>
The trick is to do some 'search and replace' in Word to change the SRT lay out into the DVDA subtitle lay out (the Word-code for <Hrt> is '^p' and the code for <Tab> is '^t'). If you manage this, make sure you save it as Unicode test with the extention .SUB and choose 'only CR' for linebreaks. Import it into DVDA as a "DVD Archtect Subtitle Script".
Hope this'll give you a second line!
LL
Tool to convert SRT/SSA to Sony DVD Architect subtitles ?
By miguelos_net in forum SubtitleReplies: 4Last Post: 4th Dec 2011, 20:48 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 06:56 -
Exctract Subtitles from .vob -> Import into Sony Vegas or DVD-Architect
By mltwitz in forum SubtitleReplies: 4Last Post: 4th Oct 2009, 02:16 -
DVD Architect-trouble with Character sets in Subtitles
By goanna300 in forum Authoring (DVD)Replies: 2Last Post: 20th Dec 2007, 05:06 -
importing mkv styled subtitles to a dvd
By rion in forum SubtitleReplies: 0Last Post: 29th Oct 2007, 09:30
