Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or Try ConvertXtoDVD and convert all your movies to DVD. Free trial ! :)
Results 1 to 12 of 12
    Apr 2008
    Israel
    hi,
    I'm trying to stitch together several .avi files with AviSynth. I'm using the SegmentedAVISource function but keep getting the message "SegmentedAVISource: no files found!". When I change the function to .avi source with the same file everything works ok. What am I doing wrong?
    Also, can anyone give me some pointers on how to stitch .avi files with AviSynth when the fps and frame size are not the same?
    Thanks!
    Can you post your avisynth script?
    Apr 2008
    Israel
    Here it is:
    SegmentedAVISource("D:\b.avi")
    Subtitle("Hello, world!")
  4. Also, can anyone give me some pointers on how to stitch .avi files with AviSynth when the fps and frame size are not the same?
    You don't. Not without making them all the same, and it doesn't look like SegmentedAVISource can do much about that. Even SegmentedDirectShowSource, while it can force them to all have the same framerate, can't force the same resolution:
    http://avisynth.org/mediawiki/SegmentedAviSource
    If you're using letters (a, b, c, d, etc.), it doesn't look to me like it works like that. You have to use numbers:
    SegmentedAVISource("D:\b.01.avi")
    Apr 2008
    Israel
    I realize I'm going to have to do some pre-processing for each file. Which functions should I use?
    Nope, doesn't work.
  6. Of course it won't work if the source files are all different. Not only do you have differences in framerate and resolution, but probably some audio differences as well that prevent them from being joined. I think that SegmentedAVISource was probably developed for captures which would all have the same properties to begin with, not downloaded AVIs from different sources and with different properties.
    Encode them with all the same properties - codec, resolution, framerate, audio bitrate, etc. And after all that it still may not work. And if it does work you won't need to use SegmentedAVISource at all, as you'll be able to join them all using the Append button in VDub(Mod).
    You didn't say what the purpose of this little exercise is. If for DVD you don't even have to join them before doing the encoding.
    Apr 2008
    Israel
    In this case there was just one file (see the script above) so no difference in properties. It still didn't work though.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    AVISource("x-201.avi").LanczosResize(720,480).AssumeFPS(23.976) ++\
    AVISource("x-202.avi").LanczosResize(720,480).AssumeFPS(23.976) ++\
    AVISource("x-203.avi").LanczosResize(720,480).AssumeFPS(23.976)
    [post edited to correct error]
    The Assumefps seems to be necessary often even when the reported fps seems to be the same, but it must be slightly different.
    See http://avisynth.org/mediawiki/AssumeFPS
    In the case where the fps is really different (23.975 and 25 fps, say) you might want to do something like ChangeFPS.
    You might do Addborders as well as Resize if the proportions are different.
  9. Originally Posted by dannoura
    Use some common sense then and just use AVISource. If it still doesn't work and you can't figure out why not, post the error message.
    AlanHK, won't you need periods after the AVISource and before the LanczosResize?
  10. Banned
    Jun 2007
    UNREACHABLE
    Well-spotted, dear Master.
    Anyway, it seems that the OP is trying to solve the difficult problems
    before having learned about the easy ones JMO.
  11. If the files are significantly different it may be better to assign variables to each clip, make the changes on each clip to change to the same parameters, then stitch them together at the end.
    V1 = AviSource("File1.avi")
    V2 = AviSource("File2.avi")
    V3 = AviSource("File3.avi")
    V1 = Lanczos4Resize(V1, 720, 480)
    V2 = AddBorders(V2, 10,20,10,20)
    Return(V1 ++ V2 ++ V3)
    This can also allow you to easily test each clip to be sure you're getting the results you want by just specifying the specific clip in the Return() statement.
    Return(V2)
    Buy My Books
  12. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Right.
    I was simplifying an old script as an example, took too much out.
    Fixed it now.
    Or if doing it all in one line gets messy, do it in blocks:
    AVISource("x-207.avi")
    AssumeFPS(23.976)
    EnsureVBRMP3sync()
    trim(120,220)
    AmplifydB(4.5)
    d7=last
    AVISource("x-208.avi")
    AssumeFPS(23.976)
    EnsureVBRMP3sync()
    trim(120,220)
    AmplifydB(1.5)
    d8=last
    AVISource("x-209.avi")
    AssumeFPS(23.976)
    EnsureVBRMP3sync()
    trim(120,220)
    AmplifydB(4.5)
    d9=last
    d7++d8++d9
    This way you can apply whatever filters you like on each file or segment separately befeor joining them.
