hello,
i've got several folders which contain files like:
VTS_01_0.VOB
VTS_01_1.VOB
and another like:
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.IFO
VTS_01_1.VOB
VTS_01_2.VOB
each folder is about 1gb. i've got numerious folders like these. (i realise there's a bit of difference between the above two examples because one is just .VOB files, the other is .VOB files plus a few others).
what's the best way to put them onto the same DVD as a DVD which is playable in a DVD player?
i've got obviously ffmpegx and also toast 6.
any suggestions much appreciated.
thanks.
folder-1/VTS_01_0.VOB -- The "0" (zero) file, a menu or intro.
folder-1/VTS_01_1.VOB -- The video file
This folder has no IFO and BUP and is therefore not a valid VIDEO_TS folder; not DVD compliant. If you would burn it as-is, most DVD players would not play it.
folder-2/VIDEO_TS.BUP -- The backup file for VIDEO_TS.IFO.
folder-2/VIDEO_TS.IFO -- The information file (commands, structure, first-play) for the whole DVD.
folder-2/VTS_01_0.BUP -- The backup file for VTS_01_0.IFO.
folder-2/VTS_01_0.IFO -- The information file for Title 01.
folder-2/VTS_01_1.VOB -- The first video segment for video title #1 (<=1 GB)
folder-2/VTS_01_2.VOB -- The second video segment for video title #1 (seamless continuation of segment 1)
This folder appears to have all the files for a valid VIDEO_TS folder; it should be DVD compliant.
Get MPEG Streamclip.
Open VTS_xx_1.VOB in MPEG Streamclip, where xx is the Video Title Set of your choice. If there are more VOBs in the same VTS, then MPEG Streamclip will ask if all segments should be opened (Yes). Convert to MPEG...
Do the same for other VTSs.
Set Toast to Video > DVD. Drop your 'converted' .mpeg files on Toast. Burn.
• If you do not have the QuickTime MPEG-2 Playback Component, then MPEG Streamclip will warn you about that, but for this process you may Continue anyway. You won't have visuals in MPEG Steamclip, though.
• You will loose any menu, subtitles, and secondary audio streams in this process, if present in the source.
How do I make a dvd data disk from these vob, bup, and ifo files?
By DHarry in forum Newbie / General discussionsReplies: 4Last Post: 4th Jul 2011, 05:23 -
Combining VOB files from different sources to create a new compilation
By bluesmanuk in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2010, 15:24 -
combining VOB files with avidemux
By majax79 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2010, 02:17 -
Combining VOB & AC3 to DV AVI Files for Editing in Premiere Pro CS4
By foochuck in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 15:08 -
Combining data files with a DVD movie on the same disk
By j_p in forum Authoring (DVD)Replies: 6Last Post: 26th Jun 2008, 02:52
