Hi there i think there is no place but here where i can ask about this.. I want to buy the Samsung SH-S203 DVD-RW- DL
But in my country the only available ones are the SATA version so i want to know if my mother board will be compatible with it because it's kinda old and i am not Sure if its SATA ports are able to deal with DVDRW.
My Mobo is the ASUS P4RD1-MX which is kind old and i ran everest to check the SATA version and here is what it said
SCSI and RAID controllers:
SCSI/RAID Host Controller
ULi SATA/RAID Controller (M1573) 1.0.0.5
So i am not sure if it's compatible with DVDRW or not..
Thanks alot.
The SAMSUNG SATA S203 dvd burner will not work correctly with the SATA controllers on your ASUS P4RD1-MX mobo. You'll have to use a PCI SATA CONTROLLER card that has the SILICON IMAGE 3112/3114/3512 chipset for the SAMSUNG SATA S203 drive to work. This is well documented at Cdfreaks.com.
Your mobo SATA controller chipset supports only hard drives. If you get the PCI SATA CONTROLLER card make sure you also DISABLE RAID in mobo BIOS. -
Thanks alot.. that' fair enough for me.. i will get these.. thanks a lot once again.
Cheers -
Well I Failed to find the required PCI SATA controller required.. and i know this is a good SATA Card will this support the DVDROM??
http://www.chiefvalue.com/product/productdetails.aspx?submit=&item=15-124-023&ATTHard%...ve%20Controlle
If not please recommend one.. Thanks alot -
I would recommend a SI chipset over the VIA chipset one you linked to. This is one from the same dealer: http://www.chiefvalue.com/product-_-productdetails.cv_-_item--CE00029919010060
WOW that was fast... Thanks a lot.. i will report back if i found better prices
Question about Installing Memory to my MotherBoard
By hellfire45 in forum ComputerReplies: 7Last Post: 24th Sep 2010, 22:06 -
Downloading Motherboard Upgrades to my Motherboard
By orfajackson in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2009, 15:54 -
Motherboard
By JcMatrix in forum ComputerReplies: 6Last Post: 16th Jan 2009, 03:20 -
Need a Core 2 Motherboard
By mn072065 in forum ComputerReplies: 6Last Post: 30th May 2007, 04:32
