Can anyone tell me how to add keyframes to timeline to control video effect. The keyframes option in the effect windows just disappears how to do it. And what is the difference betwwen DV and DVDS.
Results 1 to 10 of 10
If you mean the "hidden effect":
Just move your mouse to the bottom of the effect window, until it changes to a line.
Then drag this line up, and the hidden timeline appears. Itīs like resizing the inner content of the Effect Window.
Hope this was your problem. -
No i mean can u explain me how to use the key frames. From where i can add the key frames. I am unable to add keyframes to timeline. I want to add multiple effects to my movie which is a single clip of 45 minutes. i wnat to control the duration of different effects.
The help files cover keyframing. Basically every effect has it's own keyframes. You find them at the bottom of the configuration screen for that effect. You will have to read the help files for the specifics, but it is pretty straight forward. Change the settings, add a key frame, repeat.
Read my blog here.
U will be surprised to knwo that when i use a effect there is nothing at the bottom. The settings for the effects are there but there are no keyframes setting. They were there previously but all of a sudden they disappears. Maybe i clicked something, either they are hidden. what do u think
Try this...
1. Move your cursor to the bottom of the effects window.
2. Click and hold on to the left mouse button.
3. Drag upwards.
Watch the tutorial video here...
http://videolane.net/sonyvegas/?p=7
Sony Vegas - Scripting - Adding track motion preset
By samsam in forum EditingReplies: 1Last Post: 7th Oct 2020, 01:52 -
FFMpeg - warning: first frame is no keyframe - Encode to nearest keyframe?
By mh2011 in forum EditingReplies: 0Last Post: 3rd Nov 2011, 16:58 -
Importing avi (divx) Files in Sony DVD Architect/Sony Vegas
By mltwitz in forum Video ConversionReplies: 12Last Post: 6th Jan 2011, 07:56 -
Sony Vegas Pro 8 - Adding VideoFX to many video clips at once.
By jnaizer in forum EditingReplies: 2Last Post: 30th Dec 2008, 21:28 -
Keyframe editing not showing up in Vegas 8
By stantheman1976 in forum EditingReplies: 6Last Post: 18th Apr 2008, 07:14
