Hi,my first post....
I generally burn avi movies(xvid,divx) to dvd.....for the last while,most have been in 5.1ac3 or a52.......when i play them in my apex ad1250x,the display shows its in 5 or 6 channel and you can clearly here it......the apex is older and i have upgraded to a new rca hdmi drc275n.....which clearly is much newer and more expensive and indicates dolby digital,yet,when i put the same disc in and hit the display...it says ac3 2 channel.....then i put the same disc back in the old apex,and it says 5 or 6 channels ac3.......grrrrrrr...am i missing something...a setting or anything...lol...frustrated.
Much newer and more expensive doesn't necessary mean that it has same divx/xvid ac3 support. What does the manual say about divx with ac3 support? Tried different audio settings?
thx...
but the entire manual mentions nothing about audio codecs...funny tho,that when the movie is playing,and i hit the display,it says ac3.....only it says ac3 2 channels...lol.....i dunno....grrr -
DVD players have to use a special chip to decode Divx. There are many different models of chips and some of them differ wildly from each other. The RCA probably uses a different and quite possibly inferior chip to the old Apex player you have. The RCA may only be able to output 2 channel AC3 with Divx because of a chip limitation.
I don't associate RCA electronics with quality. Apex made a lot of great "play anything" type players in their days and I can certainly believe that this old player is better designed than your new RCA. -
thx for that info
dang...ya,the old apex played everything i threw at it.....just all used up now,probly the laser.....
bought that rca,last week,was the top one,played everythin it says,hdmi,and 3 times the money,so i never even thought it wouldnt play what the year and a half older one does.....
anyway to take that chip from the old one,and put it in the new one...lmao...
is there anyway to flash or update the new one ? -
Yes, you can update your firmware if RCA has an update available, but it won't fix your problem if the decoding chip has a hardware limitation that only allows it to output 2 channel AC3.
You would probably have been better off to have bought an Oppo player. Take a look at http://www.oppodigital.com
The downside for me is that Oppo players don't support VCD/SVCD and I do sometimes play those, particularly VCD.
Wifi Woes
By mmitcham in forum ComputerReplies: 6Last Post: 17th Oct 2010, 23:59 -
VC-1 Encoding woes...
By madmillington in forum Video ConversionReplies: 17Last Post: 16th Sep 2010, 16:14 -
Resolution woes
By newsphotog in forum Newbie / General discussionsReplies: 2Last Post: 29th Sep 2009, 13:06 -
Visualdub woes
By littleb2005 in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2008, 08:06 -
DVDShrink woes... HELP!
By tom.s in forum DVD RippingReplies: 13Last Post: 9th Aug 2007, 13:19
