hi all
first post , plz help
i have some movies , want to embed arabic subs into it in order to play it with my philips dvdr5500 ... ok , i used canopus pro coder to do the encoding with subs , selecting divx encoder (ver 6.8) and the result was very cool , all the avi's runs cool on my pc and player except for one thing ....
i can't fast forward or rewind using my philips dvdr5500 . it gave me " index information not available" error !! googling my error it seems to be a key frame error so i re encode using virtuale dup and divx 6.8 again .... got the same error ???
plz , what should i do to get my avi's able to navigate using my hardware player???
thanks ..
	Maybe you could run divfix on your output files
 Did you use too high of a bitrate? That can give some standalone players problems
 What settings for DivX? Did you use the "home theatre" profile?
 Have you ever been able to get a DivX file to navigate on that player? (not ones encoded by your process)
	thank for your fast reply ... yes , i do used home theatre profile .
 also the movies befor embeding subs runs ok and vavigate well in my player - this movies downloaded from the net - once i re encode it i cant seek it anymore . and i used varios bitrates and get the same error every time .
 what is the difference between the movies i download and the same ones after re encoding ??? don't get it yet
	If you use mediainfo (view=>text), it might show some more information on the encoding settings used for the file that does navigate. Use it on the file that navigates, and compare with the file that doesn't
 It will show something like this. It might be some setting like packed bitstream, or fps, etc...
 Format : AVI
 Format/Family : RIFF
 File size : 190 MiB
 PlayTime : 22mn 21s
 Bit rate : 1190 Kbps
 StreamSize : 1.56 MiB
 Writing library : VirtualDub build 29393/release
 Video #0
 Codec : DivX 5
 Codec/Family : MPEG-4V
 Codec settings, Packet bitst : Yes
 Codec settings, BVOP : Yes
 Codec settings, QPel : No
 Codec settings, GMC : 0
 Codec settings, Matrix : Default
 PlayTime : 22mn 21s
 Bit rate : 1052 Kbps
 Width : 640 pixels
 Height : 480 pixels
 Display Aspect ratio : 4/3
 Frame rate : 25.000 fps
 Resolution : 8 bits
 Chroma : 4:2:0
 Interlacement : Progressive
 Bits/(Pixel*Frame) : 0.137
 StreamSize : 168 MiB
 Writing library : DivX503b2510p
 Audio #0
 Codec : MPEG-1 Audio layer 3
 Codec profile : Joint stereo
 PlayTime : 22mn 21s
 Bit rate mode : CBR
 Bit rate : 128 Kbps
 Channel(s) : 2 channels
 Sampling rate : 44.1 KHz
 Resolution : 16 bits
 StreamSize : 20.5 MiB
  My DivX DVD Player can't play my avi DivX/xvid videoBy Baldrick in forum DVD & Blu-ray PlayersReplies: 32Last Post: 6th Mar 2015, 10:11
  Video from PC encoded and Burnt to VCD to Play on my DVD R PlayerBy dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 22:15
  Make MKV encoded with AVC Playable with Standalone DivX PlayerBy adalect in forum Video ConversionReplies: 2Last Post: 2nd Jun 2009, 23:42
  Cant seek my encoded divx avi's with HW players ... plz helpBy samykoka in forum Video ConversionReplies: 2Last Post: 17th Mar 2009, 14:19
  Make an unplayable Xvid/Divx video play in a divx standalone PlayerBy AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
