I want to create a dvd movie from many clips. each clip is a chapter so that when I click the player can skip and jump to the next one. Is there any free software that can do this besides DVD Flick? Thanks for all response.
the description of FAVC shows that input is avi file. My files are mpeg or vob, any other software?
Yes it accepts VOB and MPEG, but you need an .avs script and .d2v for it.
You can do it yourself with .avs scripts and HCenc, then author it using a separate tool such as DVDauthorGUI, but FAVC simplifies the process of encoding and authoring
DVD Flick would be another "easy" way of doing it.
ConvertxtoDVD would be "easy" as well, but trialware
problems making dvd from vob files only
By Dr_Sanguinary in forum Newbie / General discussionsReplies: 3Last Post: 17th Nov 2009, 08:20 -
Making DVDs from backups of VOB files
By kirklt in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2009, 09:52 -
Making movie in Vegas from MPG files
By malexi in forum Newbie / General discussionsReplies: 11Last Post: 22nd Jul 2009, 09:05 -
DVD Demuxer tool making 0kb .VOB files
By Madvillain in forum DVD RippingReplies: 5Last Post: 6th Jul 2009, 05:11 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 04:13
