    Jan 2007
    Poland
    I have problem with First Play - it doesn’t work correctly.
    I have created project in DVDLabPRO (v2.30 comp 4.00.42) consists of FirstPlay movie, Menu (Root Menu)with 2 buttons and two movie in one VTS. I have compiled DVD and burned.
    DVD goes OK in standalone DVD player but doesn’t go in PC player (in computer).
    I have tested PowerDVD v.6 and Windows Media Player v10. FirstPlay starts, play all and after end doesn’t go to the Root Menu (stops at the end - freeze on).
    If I created the same project in another software e.g. DVDAuthorPRO v2 or DVD WorkShop2 everything is OK - PC player goes correctly and standalone too.
    I have tried to put Brige between FirstPlay movie and Root Menu but it doesn’t help.
    As at you?
    Does anybody have the same problem?
  2. Member GeorgeW's Avatar
    Feb 2005
    What is the END-ACTION of the FIRST-PLAY item?
    Oct 2006
    Canada
    You have to make connection like First Play button - first play Movie- end of first play Movie connect to Root Menu.
    It will work.
    If not post the picture of your connection screen.
    Jan 2007
    Poland
    my connection
    Oct 2006
    Canada
    Your connection is fine if you get rid of the bridge and connect that line to beginning of Root menu.
    Other connections from the end of three movies are not needed, unless you have a command there, because default is to root same as movie 4 show.
    Jan 2007
    Poland
    resolved
    FirstPaly movie was corrupted,
    I also removed the bridge
