Everything was working fine until i updated a few days ago and now i am blocking 0 zero ip addresses. any thoughts on the subject? any way to reverse the update? pg2=peer guardian 2. This has happened for 3 days in a row. I have reinstalled many times. This is happening on my two pc's. I have downloaded Azureus and am trying to use the IP bloacker in it. I REALLY miss my PG. Any advise would be appreciated. Thanks.
You could try ProtoWall instead. I find it a bit harder to install, but it functions better than PG, IMO. Are you using Blocklist Manager to update? Once you have PW up and working, it's a simple process to keep it updated. BLM is also the way to update PG if you are using other methods instead. You can set it to update automatically. Look to http://www.bluetack.co.uk/forums/index.php for both.
I'm not a fan of Azureus as it seems to go right around my protection unless you set it up very carefully.
This is especiallly true with proxy servers. I also would disable UPnP, both in the program and in your LAN settings or your protections could be bypassed. I also find uTtorrent faster than Azureus and much less of a resource hog.
I got the latest version a few days ago , last night when i clicked the update button it finally updated the block list's , it took about 30 minutes to go get the P2P block list, the ads & trojans took only seconds to DL
it now says blocking 772,730,752 ip's
thats one big list -
I have Protowall set to block 2,662,429,744 IP addresses at present. It does take a while to sort them in Blocklist Manager.
Problem downloading Stopzilla updates -- Server keeps timing out
By JudgeGarth in forum ComputerReplies: 3Last Post: 24th Apr 2009, 12:37 -
AVG 8 updates?
By wulf109 in forum ComputerReplies: 2Last Post: 3rd Feb 2009, 10:49 -
Does PeerGuardian let you surf the web anonoymously, or is it just for P2P?
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 10th Jul 2008, 22:19 -
strange updates
By Tom in HD in forum MacReplies: 1Last Post: 19th Feb 2008, 21:29 -
Automatic updates?
By fLYtRap in forum ComputerReplies: 11Last Post: 13th Jul 2007, 17:46
