I am working on this website for my friend. He asked me to put a video up for a test. He sent me a MP4 video. I used my flash video encoder. Then put the flash video on the site using dreamweaver. I have three problems.
1) the video doesn't loop. I have spent 7+ hours searching and trying many things. So I have tried a bunch of things. With absolutely no luck.
2) There are ugly white borders around the video. Once again I have spent much time trying to figure this out too, with no luck.
3) One more problem, the skin where you can click play pause...etc I need to get rid of that. I'm pretty sure that happened when I put it in dreamweaver.
The site is here http://www.ushookah.com/ you can look at the test video at the bottom of the page.
If anyone has any answer or could provide and help it would be MUCH appreciated. I'm saying tank you in advance for anyone who even spends there time reading this. THANKS!!!
1) If you have flash proffesional then see this tutorial http://www.video-tutes.com/player/player.php?id=1328&T_id=5a (click on play tutorial and choose loop flv movies)
2) I guess you have tried change all the width and height in the applet?
You could also use another flash player for your flv video like http://www.jeroenwijering.com/?item=JW_FLV_Media_Player where you can set the repeat flag. -
Thanks but,
I've tried this tutorial already. Just for the sake of things I tried it again and still get the following. When I input the actions i get the following error: Syntax error: extra character found after end of program.
Thanks for the effort though! -
I would try search or ask in http://flashmove.com/forum/index.php as I don't think we are that many flash coders in here.
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13 -
Trouble downloading streaming video/flash video from site
By imi in forum Video Streaming DownloadingReplies: 1Last Post: 23rd Mar 2012, 11:08 -
Video Files, join video_ts and flash video
By Pumkinhead in forum Newbie / General discussionsReplies: 2Last Post: 6th Feb 2011, 06:45 -
Flash with high quality video (MP4 with H264 video and AAC audio)
By Baldrick in forum User guidesReplies: 49Last Post: 19th Mar 2010, 09:05
