    Apr 2006
    Pakistan
    The file is an AVI file with
    42 MB,  39992 Kbps,  30.0 fps,  320*240 (4:3),  DIB  = Microsoft DIB,    Supported
    Tried play with vlc media player?
    Apr 2006
    Pakistan
    yes and also media player classic with the latest XP CODEC PACK
  4. Run mediainfo on the file to see what codecs are being used
    I doubt the 39992 kbps is correct, but if that is true, your pc might have difficulty playing it.
  5. DIB = uncompressed video. The bitrate sounds about right for uncompressed YUY2: 320 * 240 * 30 * 2 * 8.
    The problem could be an overlay issue. Try opening with VirtualDub.
