Would like to find the following software to convert from MP3 to Real Audio. The file is to be use on MS Frontpage project. Can anyone help me ? Thank you.
If you modify your F***Page project, you will really not need to convert your
MP3 to a RealAudio file. And if you intend to become wiser, start learning to
do without MS F***Page. You have been warned. -
Easy RealMedia Producer (free)
It's normally meant for video files, but you can do just audio too.
You can change the settings for bitrate quality, RV8, RV10 etc...
Cheers -
RealProducer Basic is free too, but I don't know how much
overbloating has been added to it since 2001
<OFF-TOPIC>
I'd like to know why RealMedia does appear to be insanely popular
in the so-called Far East
</OFF-TOPIC> -
<Reply to OFF-TOPIC>
RV10, in my opinion, is really good for decent quality at very low bitrates (500-700kb/s). Maybe only slightly worse than h.264, but better than XviD/DivX. It's used for (you guessed it) file sharing of TV shows, anime etc... RV10 is actually very similar to h.264
But I don't know why they just switch to h.264?
How to find the real bitrate for an mp3?
By solitaire in forum AudioReplies: 1Last Post: 21st Apr 2011, 07:21 -
Mp3 to Mp3? Audio Compresstion / Down sampling?
By YuJay in forum AudioReplies: 7Last Post: 7th Dec 2008, 12:05 -
Good Real Audio to MP3 converter?
By Mitchum22 in forum AudioReplies: 2Last Post: 8th Jan 2008, 00:14 -
Real Audio - MP3 Converter
By soulandy in forum AudioReplies: 5Last Post: 28th Oct 2007, 16:10
