Hi all,
I am trying to convert some captured PAL DV type 1 (av locked) footage to WMV9 for web use.
The problem is that i get interlace artifacts on the WMV video image. I see wavey lines around edges that move. Static parts of the clips are not so bad.
I have been through a whole bunch of WMV profile setting but i cannot remove the interlace lines.
Does anyone have any suggestions on how to achieve this?
Vert
	Yep, you can deinterlace using wme. See my guide https://forum.videohelp.com/topic244268.html
  Convert DV type 2 to type 1? Or is there an app that will correct sync?By Colmino in forum Newbie / General discussionsReplies: 7Last Post: 20th Dec 2022, 22:24
  amazon s3 - What's the Fastest video type? (WMV / mp4 / FLV) ?By Entry in forum Video Streaming DownloadingReplies: 2Last Post: 29th Nov 2010, 12:28
  How to convert a trp type file to Mpeg2 type?By Jemes-bs in forum Video ConversionReplies: 2Last Post: 13th Oct 2010, 16:59
  type 1 or type 2 capture-newbieBy sar in forum Capturing and VCRReplies: 6Last Post: 28th Jul 2008, 19:22
  DV AVI Type 2 -> Type 1 converter?By alx3d in forum EditingReplies: 3Last Post: 29th Dec 2007, 21:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
