hi, what codec do i need ?
Results 1 to 13 of 13
try the haali mp4 splitter and maybe ffdshow
Read my blog here.
Slow encodings from the mp4 or mkv or all files you use?
What do you convert to mpeg1/mpeg2 or some other format? -
both , mp4 & mkv, i tried convert to mpeg1/mpeg2/vcd/dvd just the same, very slow, but if i convert from avi, it didn't have a problem
One of the costs of high quality compression is that it takes more effort to process the video, both during encoding, and during playback. If you are still able to convert Xvid type avi files at the same speed as before then this is simply an issue with converting H264 video.
You might also try AlltoAVI instead of tmpgenc and see how you go.Read my blog here.
oh. very very sorry, my mistake, i didn't notice it, i just now convert
avi, very slow, usually 15 minutes now more than 1 hour -
Is your computer spec in your profile correct ?
What sort of avi file converts in 15 minutes ?
From what to what ?
I find it difficult to believe anything of length or quality will convert in 15 minutes on your system. An hour actually sounds about right.Read my blog here.
Go into FFDShow via the Start menu. Open the Video Decoder Configuration program. Click on DirectShow Control, and look at the pane on the right. There is an option "Don't use FFDShow in : ". Make sure this is ticked, then click on the Edit button. Click Add, and browse to your tmpgenc folder and select the tempgenc executable. OK your way back out and try again. This should stop FFDShow decoding for tmgpenc. Of course, this may mean you can no longer use tmpgenc for your mp4 files.
Read my blog here.
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
Need help converting to MP4 with TMPGEnc Express
By rede96 in forum Video ConversionReplies: 0Last Post: 11th Aug 2011, 15:29 -
Problem subtitle edit with MKV & MP4
By whitebeard in forum SubtitleReplies: 2Last Post: 19th Jun 2011, 08:45 -
how 2 open mp4 & mkv video files in vdub
By naveenkrish in forum EditingReplies: 2Last Post: 19th Jun 2010, 22:14 -
mp4 for ipod video & mkv for mac osx
By carlosian in forum MacReplies: 6Last Post: 8th Oct 2009, 19:55
