I picked up the CD "Atari 80 Classic Games" CDROM. I love the old school games. Anyway I haven't really played any PC games in years. It installs fine. But when I run the program and choose one of the games my PC restarts. I have no idea why.
I'm running a Gateway 2.4 Ghz with 1 GB RAM. So it isn't like my PC can't handle it. I raised the resolution up higher as the readme file suggested. Any gamers or other experienced users out there know what would cause with odd issue?
You are likely getting a BSOD related to a driver issue. You can disable the XP "reboot on error" so that you can see the actual BSOD and get the error code, but I would start by ensuring all of your drivers are up to date (motherboard, audio, and video).
Google is your Friend -
Read the fine print on the cover to see if it runs under winXP. That may need a Win98SE OS.
I like MAME (Multiple Arcade Machine Emulator) over classic games "redone" for the PC.
Just a thought.... The program may want to change your video settings. And your OS may have problems with that which could cause your shutdowns.
Some older games may want 256 colors and a smaller screen size, maybe 800 X 600 pixels. If that's the problem, you could try setting them first and see if that helps. -
The disc was released in 2003. It says Windows 98/Me/XP on the back.
I'm running XP Pro
I have many emulators I have downloaded over the years. I just wanted something that my kids could also use without all the settings and other issues you have to deal with in ROMS and emulators.
Video restarts
By gcordoba in forum DVD RippingReplies: 13Last Post: 30th Dec 2011, 13:40 -
Restarts with no provocation
By dadrab in forum ComputerReplies: 16Last Post: 10th Oct 2008, 14:56 -
Computer Restarts Randomly
By peomp in forum ComputerReplies: 26Last Post: 18th Jul 2007, 01:07 -
TMPGEnc encodes to 1%, then my PC restarts
By Syntax in forum ComputerReplies: 3Last Post: 5th Jul 2007, 16:18
