Hey i am trying to capture my xbox 360 games and record them onto my computer... Now I had it set up at one point and was working but my HD TV had terriable picture because i had it set up with using only composite cables.
I am using a pinniacle movie box capture device, that has svideo/composite inputs and outputs. So with that said i can only capture at standard defination quality, and thats not a problem, i understand that.
The problem is I want to play on an HD picture, while I can capture/record with standard defintion quality.
What did I do?
I bought a input and output adapter thing hoping this would solve the problem.. I guess the best way to explain this is to tell you my exact current set up thats displaying my HD picture but my capture software is not reading it to record (Pinniacle Studio 11 ultimate)
My 360 component cables are hooked up to input 1 of my adapter
I have component cables hooked up from my adapters output to my TV's input (HD picture is displaying)
*I have composite cables hooked up from my adapters out put to my Capture device input (Not getting signal)
My capture device is connected to my computer with USB
* Is the problem . . . I thought that i had everyting hooked up correctly, I dont kno what else to try, im pretty sure the settings on my capture software are set accordingly.
Any help and thoughts are greatly appreciated
	I need help ! ! !
	I tryed finding it but nothing came up, its not a converter or any thing like that its just an adapter that has many inputs, and out puts... I think the problem might be that component cables can only tansfer through other component cables....so thats why it transfers to my TV only....And is why its not trasnfering to my capture device cuz its hooked up ot that via composite as i said, and only has composite inputs.
 please tell me i am wrongI need help ! ! !
	When I read your post I came to the same conclusion - because this is just an adapter, and not a converter, you will not get composite output from component input. I would return the adapter and look for something more appropriate.
 Before you do, does the adapter have s-video out ? If so, give that a try. It is easier to get s-video out from component in that it is composite out.Read my blog here.
	yes it has S video . . . I tryed it still no signal . . . yeah i think i am going to take it all back and get this
 http://www.myhava.com/product_hava_platinum_hd.html
 I herd this was the only way to be able to play 360 games in HD and record/capture in standard definition.
 But yeah i dont even know i'm not good with this kind of thing obviously.. you think the Hava device should work for what im trying to do?I need help ! ! !
	It should be possible. It can downscale HD looped input to SD output.
 Call HAVA to confirm this.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Sorry i was trying to say im thinking about taking everything back (Svideo does not work with component)
 I am considering getting this:
 I think this hava product will let me play in HD and record in 480i correct me if i am wrong?
 I also dont know if i would need to get the platinum one or the wireless thats a little more pricey, When i called there support earlier i could not understand what he was trying to tell me as far as if it would work or not for what im trying to do because he did not speak english that wellI need help ! ! !
	It would seem to. Call HAVA for advice on model. Tell them what you are trying to do.Originally Posted by dpunkzRecommends: Kiva.org - Loans that change lives.
	Go to specs > view > 1: A/V capture base-band inputs (Composite, S-Video, Component) = No go for HD
  How to capture gameplay from XBOX360 to AVERTV capture cardBy Ollie999 in forum Capturing and VCRReplies: 2Last Post: 25th Oct 2011, 21:16
  Xbox360 to pc captureBy Bjs in forum User guidesReplies: 4Last Post: 14th Aug 2011, 20:54
  *HELP* Capture xbox360 need adviceBy trusoljuh in forum Video Streaming DownloadingReplies: 0Last Post: 7th Apr 2010, 15:32
  Using My TVTuner Card to Capture XBOX360 GamingBy Jimmy058910 in forum Video Streaming DownloadingReplies: 1Last Post: 25th Sep 2008, 15:49
  VGA Capture and record?By shifterkart in forum Newbie / General discussionsReplies: 2Last Post: 9th Feb 2008, 11:52
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
