  1. Banned
    Oct 2007
    US
    I have noticed that Dell has announced a 30" monitor, and some people just thinking about use it for gaming:
    http://forums.toonzone.net/showthread.php?p=2827283#post2827283
    Well personally I do think that too expensive for me, with that budget I can get a tv.
    May 2007
    reality
    A monitor is a monitor...a TV is a TV. Square peg, round hole. Round peg, square hole. The square is actually more of a rectangle. There are big differences and the application would determine what product would best suit the requirement.
  3. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    Many users seem to like using a 24" monitor for gaming, but to me it just seems like overkill. I finally have a PC and video card fast enough to run new games at 1680x1050 with the quality settings on high. Moving up to a 24" monitor would mean running at 1920x1200 and I would then again have to reduce the quality settings.
    Google is your Friend
  4. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Why are they exclusive? I run two big LCDs on my main workstation at home that are 1920x1200/1080 off one video card. One is 24" and one is 37". The 24" is good for gaming. Any bigger and I'd have to sit further away from it. The 37" never gets used for gaming, it is for home theater purposes and extra pixel real estate for design/layout apps. The difference between a good 1080p LCD and that Dell monitor is a little extra vertical resolution and a quicker refresh time. Dollar for dollar the 1080p LCD TV with DVI inputs is probably going to be the better investment overall.
    FB-DIMM are the real cause of global warming
  5. Banned
    Oct 2007
    US
    I don't think that 30" monitor have very nice specifications.
