hey i have a movie that i downloaded from the net. when the movie downloaded it came in two parts. the file type i think is Xvid. is there a way to combine the file type to put it onto a dvd or is there another way. i prefer mpeg files.
	AVI Demux will happily combine them (file -> load, then file -> append - remember to add.avi to the file name when you save)
 If you convert them to mpeg files they will be 4 times the size if you want the same quality. Only convert them if you want to make a DVD, in which case use DVD Flick and let it join, encode and author them.Read my blog here.
  How to convert DV avi files to DVD ready MPG files with Win7 powershell.By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 17:42
  Use .MTS files in Final Cut Pro while keeping original dates in the filesBy Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 17:21
  Why doesn't MKV files play BD PGS/sup files in software or hardware playersBy cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 13:10
  Is it doable to convert HDV/.m2t 1080i files to AVI files and what...By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 05:03
  whats best to use to copy my home videos to DVD... avi files or wmv files??By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 05:24
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
