I've been using Windows Movie Maker and now have a file in DV-avi format.
I have Xilisoft Video Converter.
I want to convert my DV-avi so I can burn it to DVD but I'm not sure what format to use.
Should I just turn it into .vob (which was its original format before I converted for editing in Movie Maker)?
This is possibly further complicated by the fact that I don't have a DVD burner in my PC. I will be transferring the file over to my friend's Mac and he will burn it to DVD for me. Hopefully, this is possible.
Thanks.
Xilisoft = Crap.
How are you going to transfer it to the Mac ? If you create the DVD structure on your PC, it will potentially be large - up to 4.38 GB. Without a burner that might be hard to transport.
If you compress the file to make it smaller so you can transport it easier, you will reduce the quality, probably a lot.Read my blog here.
You can always get Flash memory stick 8GB, but it will cost you about twice as much as new DVD burner.
Creating DVD-Video from 6 AVI files
By rock_king_my in forum Authoring (DVD)Replies: 4Last Post: 9th Jun 2010, 22:42 -
Creating DVD from .avi files.
By gillie_bhoy in forum Authoring (DVD)Replies: 3Last Post: 20th Jan 2010, 15:21 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 22:43 -
Editing, Creating DVD from "Microsoft Recorded TV show" format
By mb90078 in forum Media Center PC / MediaCentersReplies: 6Last Post: 8th Aug 2008, 20:40 -
I am creating a PPM format movie and want to display it w ffmpegX
By kesnermodoc in forum Newbie / General discussionsReplies: 0Last Post: 19th Jan 2008, 17:00
