    May 2006
    Will Office XP Pro run on an XP Home system? I have had second hand reports of problems.
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    I don't see why not. The only difference between Office Pro and a normal bundle would probably be the inclusion of FrontPage, Publisher, Visio, or OneNote? Aside from that the applications alone work on XP Home or Pro equally.
    FB-DIMM are the real cause of global warming
  3. It ran fine on one of my laptops that had xp home as default installed from the OEM.
    The good old "They say". If XP Home runs OK, then XP Pro will as well.
  5. Sorry, I should add XP Home was installed first from the OEM, and I later installed Office XP Pro later without problems (not Office XP Pro installed by the OEM)
    Nov 2006
    The pro and the home notation of the different software and OS don't exclude each other. So yes, it should run just fine.
