I pulled terabytes of HD content onto the PC via HDVsplit and the file extensions are .M2T
Now it seems that it is some kind of wrapper/transport that the Mac does not like. How do I go about making them Mac friendly? Thanks
Do you want to play it, or do some other operations on the file?
VLC should be able to play .m2t streams. It also can transcode into other formats, if that's what you want to do. VLC is free.
There are undoubtedly many other apps that can work with .m2t streams, but without knowing more about what you want to accomplish, it's hard to say much specific. If you post back with a little more info, I'm sure that you'll get lots of useful suggestions from others on this forum. -
I'd start with MPEG Streamclip where you can do basic cutting and trimming of the .m2t videos. If you want to export segments for use in iMovie or FCP use Streamclip to convert to full quality QuickTime Movie.
Editing MPEG1/2 is lossless if you edit to the GOP (the GOP length can be up to 0.6 seconds). Editing to the frame needs decoding-encoding which may introduce quality loss.
And of course converting MPEG to DV for iMovie will lose quality especially if you convert the material back to MPEG with iDVD. MPEG->DV quality loss is minimal (scaling may introduce its own artifacts, though).
Canon HF10 w/ Corrupted .m2t files
By greymalkin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 26th Aug 2011, 19:27 -
how to enable ffdshow for m2t files playback?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Jul 2009, 14:33 -
join & split m2t files
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 1st Dec 2008, 21:15 -
Adobe Bridge m2t files
By vegasarian in forum Newbie / General discussionsReplies: 0Last Post: 5th May 2008, 10:39 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 05:03
