My computer has a few viruses and I note that the "Hide protected operating system files Recommended" (under My computer>tools>folder options>view ) has disappeared. Also, if I choose "Show hidden files" and uncheck "Hide extensions", still I cannot see hidden files. When I reboot the computer, then "Do not show hidden files" is automatically checked again (against my will). I found the only way I can see (and delete) the hidden files, is to click on any Winwar archive and then I can browse for and see the hidden files. Also, my cpu usage is constantly at 100% (taskmanager.exe is running very high, even at idle). So I can't even watch a video because the cpu is running near 100% from some unknown reason. Given these symptoms, I wonder if anyone can tell me what kind of virus would cause these problems. So far, I was able to seemingly eliminate the problems by restoring by Ghost, but even the Ghost program would not start in Windows properly. I would just like to know what kind of virus could cause these symptoms. Also, I found a lot of pagefile.pif files on the hard drive and another file C:/Windows/system32/ Com/ Isass.exe
(among other mysterious files) that all disappeared when I restored with Ghost to seemingly normal operation. Before restoring with Ghost, I deleted the above mentioned mysterious files, but that did not improve the situation. I would sure like some idea what kind of virus would cause these symptoms.
I looked at the above website. Since there is little explanation in English, can you give me some pointers before I try to use that software?
wtfI looked at the above website. Since there is little explanation in English,
Is your web browser being redirected to the Polski pages,
or something,
Question about disappearing program in the "Open with" dialogue
By jimdagys in forum ComputerReplies: 2Last Post: 4th Dec 2009, 03:35 -
Operating System Suggestions
By radiotaught in forum Newbie / General discussionsReplies: 30Last Post: 3rd Jun 2009, 08:40 -
What's your primary Operating System?
By freebird73717 in forum Newbie / General discussionsReplies: 13Last Post: 26th Aug 2008, 19:26 -
Which Operating System
By Craig Tucker in forum Off topicReplies: 9Last Post: 16th May 2008, 18:52
