I try to create a short motion menu at first (just 20s) and then
jump to the static menu. I do all the motion by vegas and drag
it to the DLP, but it comes with problems
1) Indeed I have a background audio also , is it possible that the audio just available in
the motion menu not in the static menu?
2) When I have finished all my menu and compile it, the motion menu come normally,
but after that the static menu can't shown but only the object has shown, I wonder if I
have done anything wrong
3) Does anyone know how to restrict the menu so that when the user click the menu button,
it does not show the motion menu again (i.e. The motion menu show only once)
Many Thanks![]()
Results 1 to 30 of 60
Is it actually a motion menu, or just a video clip to play before the static menu ?
A true motion menu have video running in the background the whole time.
If you just have a clip to play before the menu runs the first time, create the clip as a movie, not a menu. In the connections window, link the First Play item to the movie, then link the movie to the menu. Set the menu as the root menu, and this is where the viewer will return to. The clip will only play the first time the disc is run.Read my blog here.
Motion menu can have both video and audio, but if you want to do what you say, than follow guns1inger advice.
you tell exactly what I want! really thanks guns1ingerOriginally Posted by tinker
last Q: That means I don't need to use 2 cells to make my menu?
Just make a clip then a static menu, in the connection box, do the linkage and the first play menu settings as you say, am I right?
Again many thanks
You can use two cells, but this is much more involved. The basic step is to create you video, including the section with the menu, as one video clip. This means deciding up front where the menu will start, and making sure your audio can happily loop to this point. I usually have the menu text fade in at this point, and have the music fade out and then back in again, or have it fade out and stay out for the menu section.
You then load this into your menu in DLP, and set the end of the first cell to be point where your menu fades in. So far, it is all pretty simple. In Cell two you set you subpictures to mark the menu selections, and your menu is done.
The hard part is getting the first section of the menu to play once, and once only. This involves getting into the registers and setting a register value after the menu plays the first time, then checking this value on each subsequent play and skipping the first cell if it has been played before. I had to search the posts in the DLP forum at Mediachance to find the answer (which I don't have on this machine, sorry).
So why bother ? The advantage of using cells is that the transition between menus is seamless. No break in the music, no pause in the video. You will still get these when you loop the second cell, but by then it doesn't matter. However, if you are going from motion intro to still menu the difference isn't so great, and the effort may not be worth it.Read my blog here.
but how to set the register so that when one press the title button, it will not play the video again, instead it will play the static menu I have designed in cell2?(Indeed I also want all the "Return to Main Menu" button will link to the static menu but not the clip.)Originally Posted by guns1inger
And I have another problem, I try to put the motion menu (including the static scene I want to appear after the motion menu) in the first cell, and copy the last scene of the motion menu to the menu as cell2, and then azdd the button in DLP in cell 2, the problem is after playing the short clip in cell1, it then goes to cell2 but it shows invisible button, but I have set both of the button in visible mode, why is it happen? -
All I can offer are the posts I followed at the DLP forums at Mediachance.
http://www.mmbforums.com/ipb/index.php?showtopic=16553&hl=delayed+cell
http://www.mmbforums.com/ipb/index.php?showtopic=14797&st=0&p=85012&#entry85012
and suggest you search further there. They seem to have culled some of the older posts that also had info, but there should be enough here to get you started.Read my blog here.
Try adding the following 2 lines to the PRE-COMMANDS of the menu with the multiple cells.
if (GPRM0 > 0) LinkCN 2 (button 0)
GPRM0 = 1
Regards,
George -
I have succeed to control the situation so that when the user press theOriginally Posted by GeorgeW
title button again, it will not play the clip, but I have 2 menus (1 is the
menu with 2 cells as mentioned before, and the other is the scene
selection menu, the scene selection menu has the button called "return
to main menu" I have set return to cell2(ie the static menu ) but after compile
it stills plays the clip again, do I need to set other VM commands again to
control that button?
It really works! thanks guns1inger~ But the items in the cell2 in the mainOriginally Posted by guns1inger
menu does not appear unless I highlight it(Actually I have made the text
blue and the text becomes pink when I higghlight it,but now the situation
is it jst appears pink without showing the blue text), I wonder I should make
the text in vegas instead of in DLP
You can only make the background text in Vegas. The sub-picture, or highlight, has to be done in DLP or as an external sub-picture in photoshop. If you add text in DLP that you want to have as background text on a motion menu, you have to Render Motion, which re-encodes the menu to AVI, which you then have to re-encode again to mpeg-2 and re-import.
My process is to create the entire menu in Vegas, then use abstract pointers added in DLP for the menu marks. Saves having to line up the text overlays etc.Read my blog here.
I got your point ~really thanks. A silly question: I am now making menu in 4:3 ratio,Originally Posted by guns1inger
can DLP edit the menu in 16:9? -
DLP can make 16:9 menu, you just have to set it that way in Project Properties.
thanks manOriginally Posted by tinker
I post the Q here coz I don't want to waste a new post:
I try to edit my menu in vegas, but I encounter problems
when I try to input text (which is mixed with the video)
How can I make the input text shown on the primary track?
(I have done the mask in the relative area in the primary track,
but it seems that only the second track can be seen in the primary
track, but the text layer cannot make it appear in the primary track),
does anyone have an idea to make the track visible in the primary
track?
Move the text track to be on TOP of the other tracks...
Regards,
George -
yep.Originally Posted by GeorgeW
Think of the Vegas timelines as being panes of glass, with you looking down from above. You can see through the holes in the top pane to the panes below. If you block the whole of the top pane, say with an image, you can't see through to the ones underneath. You have to stack the panes in the right order to be able to see all the levels.Read my blog here.
I face another problem when I try authoring menus with different aspect ratios, is DLP allow users to create menus with a mix of 4:3 and 16:9 aspects? I try to edit the VTS properties of 1 of the menu that I wish to change to 4:3 menu, but it seems that it helps me to change all 5 menus, is it possible to change only one menu?
Do I need to create one more VTS menu and link that menu to the menu in VTS1, and set the root menu and first play buttonlinked to the menu in VTS2?
The menus should match the aspect ratio of the video in the titleset. So if titleset 1 (VTS1) has 16:9 video, it should have 16:9 menus.
The way to get around this restriction is to create menus at the VMG level, then use bridges to move between the titlesets. It is all covered in the help files. Have a read about the VMG level and bridges in the help files.
This is also why you should plan the actual structure and attributes out on paper before starting to build.Read my blog here.
Let me try the VMG menu and see if it works~Originally Posted by guns1inger
btw: What is the way of using VMG menu? In the same VTS, DLP just allows one aspect ratio, I still can't change the VMG menu into 4:3, it helps me to convert the other VTS menu at the same time
Is it really limited this way in DVDLab?Originally Posted by guns1inger
The other applications (like TDA, DVDRemake) allow for different AR of menus and the movie in the same VTS and it always works. The limitation is to have the same AR for all menu pages inside a VTS, or within video manager menu. -
[quote="ihmcjacky"]
Menu does not have to have the same A/R as Title, but all menus have to be same A/R and all titles have to be the same A/R in one VTS.Originally Posted by guns1inger
That is, if one Menu is 4:3, all other have to be 4:3 in the same VTS. If one title is 16:9 all other have to be 16:9 in same VTS.
DVD Lab has the same option. -
[quote="tinker"]
oh what a shame!Originally Posted by ihmcjacky
Maybe I'll need to edit my main menu again...
A little bit confused. What do you mean by sub-picture? Is that only a jpeg file withOriginally Posted by guns1inger
only one color? What actually does the sub-picture function? I have created the DVD
now with abstract pointers, but when I put in my DVD player, it can not detect my
first button and consequently I can't select the object!(which is created in vegas)
As you can see on my previous post I have a motion menu which there is a small
video at the top of the jpeg file, and there is a fade in of the topic and the objects
like scene selection in the first 4s, the point is I want to let the objects there with
the motion menu continues to run(ie the motion menu and the object appears
simultaneously after the fade in time, instead of motion menu then static menu)
It is a little bit different as I mention at the top most of the post, but I just can't understand
why my player can't recognize my first invisible button. Any ideas? -
ps: Wanna ask guns1inger how to match the abstract button with the object in vegas in a faster manner under DLP, I found it hard to match the abstract buttons with the text, I need to compile several times in order to get the correct position, would you share how you match the abstract buttons in a faster and proper manner?
Regards ihmcjacky
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08 -
Motion Menu Buttons
By lapetite_66 in forum Authoring (DVD)Replies: 5Last Post: 29th Jul 2009, 15:45 -
Creating buttons on a motion menu
By jrd3263 in forum Authoring (DVD)Replies: 2Last Post: 16th Nov 2008, 16:13 -
Menu Problems - No Roll Overs - Where are I in the menu?
By dunncha in forum SVCD2DVD & VOB2MPGReplies: 81Last Post: 10th Nov 2007, 07:40 -
Static Text in menu
By paparilly in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Jul 2007, 06:35
