Hey!
I downloaded Super to Vista... But when i try to run it, it does'nt open not even an error opens........ I tried to run it as adminstrator but does'nt work either and then i searched on VideoHelp forum and found out to try to uninstall it again and set it up as an adminstrator but still nothing comes up not even with UAC off....
PLZZZZ HELP!!!
Results 1 to 24 of 24
The last couple of versions have all run on Vista, however they do take a while to load, and the previous versions would sometimes need to be executed twice before they loaded. The current version does not need to be "Run As Administrator". Normal execution works.
Read my blog here.
I tried that too...
But is it because of i haven't got the Vista SP 1?
Cause i'm waiting for the danish version.
I have used the latest version on Vista and SP1 recently. It does work. Check your firewall and see if it is blocking Super from checking for updates. As I recall I had a problem at one time where my firewall was blocking that action and Super didn't start because of it.
--dES"You can observe a lot by watching." - Yogi Bera
http://www.areturningadultstudent.com -
Have you tried running in compatibility (XP or 2000 even) mode? Not sure if it will help, but it's worth a try.
edit: Properties -> Compatibility -> (check) Run this program in compatibility mode for: -> choose OS (may default to XP SP2 mode). -
The install should put ffmpeg.exe inside the Super folder. There isn't any user assistants required in the install.Originally Posted by LoveMyslf
I mentioned it earlier as a thing to check for. About a year ago I installed a different version of ffmpeg into the Super folder and it prevented it from running.
Yeah, that's what I did once and it stopped working.Originally Posted by LoveMyslf
How about a complete uninstall and reinstall of Super?
Ooh...! 8)
Well now i completely reinstalled it. But still not working...
now i completely reinstalled it but still not workingOriginally Posted by Des
Well, I'm out of ideas
You could try contacting the folks who created Super.
Ok thanks anyway for all the suggestions.
But if something comes up plzz write. -
Read my blog here.
Have you tried installing by right-clicking on the installer EXE and running/installing as administrator? (Rather than simply entering the admin password when the installer runs normally.)
I think eRightSoft still recommends turning UAC off, but I don't. It's your call. But, yes, do try other alternatives as well, such as Xvid4PSP (as guns1inger mentioned), WinFF, etc. I haven't felt like installing SUPER on Vista, to be honest... and actually haven't tried using it in a long while.If cameras add ten pounds, why would people want to eat them? -
So is Super not the best choice? I haven't had to do much converting outside of Premiere so I am just now getting a feel for all this.
I will try to uninstall and reinstall making sure I have the latest version. I do have UAC on so that may be the issue.
But I think I will also try these other recommendations, Xvid4psp and Winff. Thanks for the input.
Ed -
I'm not sure if this is still relevant, but I had the same problem. And found a solution to it. I checked to see if my firewall was blocking it - I didn't want to have to check all of the rules and policys of the firewall so I added SUPER to my trusted applications list. To select the program for the trust application list - I had to find the process. It gave me a process list and I found SUPER - it had a sub process (CMD.exe). I found out that it might have executed this a couple of times and froze - Just open task manager and close every instance of CMD.exe and it should start fine.
- Justin Reno -
I had that same problem. I tried to run the program and nothing happened except for an error.
Here's what I did to fix it:
1) uninstall SUPER
2) restart computer
3) run the installation file "As Administrator"
4) run the program "As Administrator"
Hope this helps someone! -
Everybody! I am back on this thread looool! Anyways I reinstalled Vista and now it works fine! Reinstalled 3 months after I made this thread. And lol can't believe this thread's still active! xD
What is AVI(for pocket PC) in Super?and keep aspect ratio in Super ?
By SingSing in forum Video ConversionReplies: 2Last Post: 19th Dec 2009, 22:05 -
SUPER - is it really super? (a behind-the-scenes look)
By BaronJT in forum Video ConversionReplies: 5Last Post: 2nd Aug 2009, 09:29 -
SUPER - Best Replacement that is Vista Compatible?
By heyjjjaded in forum Portable VideoReplies: 11Last Post: 8th Oct 2008, 08:39 -
What is the difference between Vista basic and Vista home premium?
By davidsama in forum ComputerReplies: 18Last Post: 27th Oct 2007, 13:01 -
Installed Vista, and Super does not work anymore? Any
By tzm in forum Video ConversionReplies: 1Last Post: 5th Jul 2007, 23:05
