Good day to everybody
I converted a movie ( AVC, AC3) in another one ( Xvid, MPEG-1 Audio layer 3) with VirtualDub.
The original file had 700 MB and the second one 500 MB. One said me that the lesser MB the lesser quality. So I ask for your help to tell me what parameter of the process (VirtualDub) must I actuate to obtain the near value of 700 MB?
Thank you for your answer.
Cheers.
Increase the video bitrate and you will get bigger file size and probably a bit better quality.
In virtualdub under video->compression->xvid mpeg-4codec and click configure.
Click on the Target Quantizer button and it should say Target Bitrate
Then click on the calc button
Set the target size to 716800(700MB)
Set the video hours and minutes
Set the MP3 bitrate
Hit OK
Or use Autogk, load the avi and set the output file size and convert. -
You can calculate the average bitrate in a movie yourself, use a bitrate calculator(see our tools list) and put in the file size, the audio bitrate(from mediainfo,gspot) and it will tell you the average video bitrate.
I don't know how mediainfo and gspot reads the bitrate, I guess it's different because it's Variable Bitrate(VBR).
I need some sound bytes if that is possible.
By ingeborgdot in forum AudioReplies: 4Last Post: 25th Apr 2012, 20:53 -
Need number of bytes played per millisecond
By rpolavar in forum Newbie / General discussionsReplies: 14Last Post: 27th Aug 2010, 00:41 -
ffmpegX - flv to mp3 - no bytes
By Noodles4 in forum ffmpegX general discussionReplies: 6Last Post: 5th Aug 2010, 19:45 -
says it succeeded but file is 0 bytes in size
By mlevin77 in forum ffmpegX general discussionReplies: 6Last Post: 21st Oct 2008, 17:04 -
Unneeded Bytes At The End Of DivX Video
By kinlunyu in forum Video ConversionReplies: 1Last Post: 11th Jun 2008, 11:01
