				Results 1 to 15 of 15
	It is a single channel (mono) audio clip running at 8000Hz and compressed at 33kbps, however whatever created it has tagged the codec required as DEVELEOPMENT. Without knowing what codec was actually used to encode the file, there is little chance of getting anything useful from it.
 What is it's origin ?
 Edit : a little scrounging in google says it's encoded with Micronas InterMetall Speech MI-SC4 v.4.2.4, but I can't find a codec for it anywhere.Read my blog here.
	Maybe this:
 http://www.codec-download.com/modules.php?name=Downloads&d_op=getit&lid=510
 Nevermind, the link was dead.
	Link isn't dead. The file is now attached to this post. Although it doesn't seem to help with the test file . . . . . .
 mi-sc4.zipRead my blog here.
	The link probably didn't work for me because I have cookies blocked by default.
	Would you mind telling us where you found that unplayable audio file
	Well, it's still early in the day for Canada, so he might respond later, but given the subject of this post, I'm amazed that so many of you want to help this guy. That was a pretty rude way to ask for help. Or maybe it's just a test and he has deliberately created a file that you guys can't play, just to mess with you.
	@ jman: thanks for the alarm-clock  (seriously) (seriously)
 @ the OP: see link below :P
 playable.wav
	I didn't intend for my subject to sound rude...I thought I'd just try to spark some competition. The file is real and is not a trick, and I've literally been trying for over a year (on and off) to try and find a way to play it. I've tried the mi-sc4.zip before, but unfortunately it didn't work.
 Midzuki: is that the converted file? is the file only static? (that would be an extremely disappointing end to this mystery.
	I'm no audio expert, but the audio file plays back: "Hello, hello, _____ is a dork"
 I won't spill the beans on how I got to play it back just yet
	2) You still haven't told us where you found the damn test.wav
 1) Like it or not, jman98 is right --- your opening post did sound
 trollish. As for the file playable.wav: I opened test.wav in GoldWave
 as an 8kHz-sampled mono bytestream and simply saved the result as
 an uncompressed, "hearable" audio file. Why? Because I serious doubt Why? Because I serious doubt
 the original mysterious.wav can really contain anything worth hearing.
	The codec needs to be registered. The system won't know to associate the fourcc code with the codec until it is. It needs an INF file.Originally Posted by rimmonhouse
	I downloaded this driver
 http://members.driverguide.com/driver/detail.php?driverid=635417&action=filfo
 and installed it on a virtual machine. The WAV file matched Poisondeathreay's mp3 file.
  HC Encoder input file challenge/ AVIsynth script?By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 16Last Post: 10th Jan 2014, 14:02
  A TRUE challenge regarding creating / playing MP4 files with my new HTC HD2By Anthony Als in forum Newbie / General discussionsReplies: 9Last Post: 4th May 2010, 12:14
  Unique Compression Challenge: Large QT Files for Streaming and Download ...By benjifranklin in forum DVD RippingReplies: 1Last Post: 14th Oct 2008, 14:55
  I CHALLENGE someone for a capture solution .....By sungator in forum Capturing and VCRReplies: 18Last Post: 12th Mar 2008, 19:59
  This Is A Loaded Question For You Video/Audio Experts Out There...By pmolson in forum Newbie / General discussionsReplies: 2Last Post: 20th May 2007, 14:32
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
