I failed to burn a .VOB file cut by using DVD Cutter 1.0 four times. The errors occured during the burning process or verification. Here is the latest error log:
ARIF BUDIMAN
LIBRA STAR CORP. LTD.
4C87-200M-3005-E10K-000X-X640-0800-4049-233A-**** (*)
Windows XP 5.1
IA32
WinAspi: -
NT-SPTI used
Nero Version: 7.9.6.4
Internal Version: 7, 9, 6, 4
(Nero Express)
Recorder: <TSSTcorp CDDVDW SH-S202J>Version: SB01 - HA 1 TA 0 - 7.9.6.4
Adapter driver: <IDE> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <SAMSUNG CD-ROM SC-152L >Version: C100 - HA 1 TA 1 - 7.9.6.4
=== Scsi-Device-Map ===
DiskPeripheral : Maxtor 2F030J0 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : TSSTcorp CDDVDW SH-S202J atapi Port 1 ID 0 DMA: Off
CdRomPeripheral : SAMSUNG CD-ROM SC-152L atapi Port 1 ID 1 DMA: Off
=== CDRom-Device-Map ===
TSSTcorp CDDVDW SH-S202J E: CdRom0
SAMSUNG CD-ROM SC-152L F: CdRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 31457280 (0) Byte
BUFE : 0
Physical memory : 182MB (186868kB)
Free physical memory: 61MB (62924kB)
Memory in use : 66 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
6.4.2008
CD-ROM (ISO)
4:46:51 PM #1 Text 0 File SCSIPTICommands.cpp, Line 424
LockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
4:46:53 PM #2 Text 0 File Isodoc.cpp, Line 6663
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : TAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
4:46:53 PM #3 Text 0 File Burncd.cpp, Line 3196
Super Link activated
4:46:53 PM #4 ISO9660GEN -11 File Geniso.cpp, Line 3343
First writeable address = 0 (0x00000000)
4:46:53 PM #5 Text 0 File Burncd.cpp, Line 3508
Turn on Track-At-Once, using CD-R/RW media
4:46:54 PM #6 Text 0 File DlgWaitCD.cpp, Line 307
Last possible write address on media: 359848 ( 79:59.73)
Last address to be written: 325211 ( 72:18.11)
4:46:54 PM #7 Text 0 File DlgWaitCD.cpp, Line 319
Write in overburning mode: NO (enabled: CD)
4:46:54 PM #8 Text 0 File DlgWaitCD.cpp, Line 2964
Recorder: TSSTcorp CDDVDW SH-S202J;
CDR code: 00 97 27 28; OSJ entry from: Princo Corporation
ATIP Data:
Special Info [hex] 1: F0 00 80, 2: 61 1B 1C (LI 97:27.28), 3: 4F 3B 4A (LO 79:59.74)
Additional Info [hex] 1: 00 00 80 (invalid), 2: 00 80 00 (invalid), 3: 00 80 80 (invalid)
4:46:54 PM #9 Text 0 File DlgWaitCD.cpp, Line 493
>>> Protocol of DlgWaitCD activities: <<<
4:46:54 PM #10 Text 0 File ThreadedTransferInterface.cpp, Line 793
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 325212 (325212) = #325212/72:16.12
relocatable, disc pos for caching/writing not required/ required
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 325210 blocks [E: TSSTcorp CDDVDW SH-S202J]
4:46:54 PM #11 Text 0 File ThreadedTransferInterface.cpp, Line 995
Prepare [E: TSSTcorp CDDVDW SH-S202J] for write in TAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1: Idx 0 Idx 1 Next Trk
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 307200 666341376, ISRC ""
DAO layout:
___Start_|____Track_|_Idx_|_CtrlAdr_|_____Size_|__ ____NWA_|_RecDep__________
-150 | lead-in | 0 | 0x41 | 0 | 0 | 0x00
-150 | 1 | 0 | 0x41 | 0 | 0 | 0x00
0 | 1 | 1 | 0x41 | 325212 | 0 | 0x00
325212 | lead-out | 1 | 0x41 | 0 | 0 | 0x00
4:46:54 PM #12 Text 0 File ThreadedTransferInterface.cpp, Line 1066
Removed 2 run-out blocks from end of track 1. Length: 325212 -> 325210.
4:46:54 PM #13 Text 0 File SCSIPTICommands.cpp, Line 215
SPTILockVolume - completed successfully for FSCTL_LOCK_VOLUME
4:46:54 PM #14 Text 0 File Burncd.cpp, Line 4294
Caching options: cache CDRom or Network-Yes, small files-Yes (<64KB)
4:46:54 PM #15 Phase 24 File dlgbrnst.cpp, Line 1762
Caching of files started
4:46:54 PM #16 Text 0 File Burncd.cpp, Line 4413
Cache writing successful.
4:46:54 PM #17 Phase 25 File dlgbrnst.cpp, Line 1762
Caching of files completed
4:46:54 PM #18 Phase 36 File dlgbrnst.cpp, Line 1762
Burn process started at 48x (7,200 KB/s)
4:46:54 PM #19 Text 0 File ThreadedTransferInterface.cpp, Line 2721
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
4:46:54 PM #20 Text 0 File MMC.cpp, Line 22363
Set BUFE: Super Link -> ON
4:46:54 PM #21 Text 0 File ThreadedTransfer.cpp, Line 269
Pipe memory size 31422400
4:47:57 PM #22 SPTI -1135 File SCSIPassThrough.cpp, Line 179
CdRom0: SCSIStatus(x02) WinError(0) NeroError(-1135)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 00 00 00 70 40 00 00 20 00 00 00
Sense Area: 0x71 00 03 00 00 00 00 0A 00 00 00 00 0C
Buffer x09126900: Len x10000
0x8F 43 AA E4 C6 22 23 F3 48 C1 1A A4 72 2D DE 8C
0x37 90 44 99 69 9B 1F 68 BD 91 7F 06 C9 E7 8F 8B
0xA6 2D 74 E1 AF EA AC 23 84 FD 8F 22 7B B0 A1 42
4:47:57 PM #23 CDR -1135 File Writer.cpp, Line 303
Write error
4:47:58 PM #24 CDR -201 File WriterStatus.cpp, Line 195
Invalid write state
4:47:58 PM #25 TRANSFER -18 File WriterStatus.cpp, Line 195
Could not perform EndTrack
4:47:58 PM #26 Text 0 File MMC.cpp, Line 17131
<TSSTcorpCDDVDW SH-S202J > start Close Session
4:48:21 PM #27 Phase 38 File dlgbrnst.cpp, Line 1762
Burn process failed at 48x (7,200 KB/s)
4:48:22 PM #28 Text 0 File SCSIPTICommands.cpp, Line 261
SPTIDismountVolume - completed successfully for FSCTL_DISMOUNT_VOLUME
4:48:25 PM #29 Text 0 File Cdrdrv.cpp, Line 11185
DriveLocker: UnLockVolume completed
4:48:25 PM #30 Text 0 File SCSIPTICommands.cpp, Line 424
UnLockMCN - completed sucessfully for IOCTL_STORAGE_MCN_CONTROL
Existing drivers:
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
This is the first serious problem I experience since I use the DVD Writer. My PC specification: ECS P6VEM2 mainboard with onboard VIA C3 733 MHz FSB+vga+soundcard, 192 MB SDRAM, AIBO 300 watt PSU (AC 230 V), 30 GB Maxtor 7200 rpm HDD, Samsung CD-ROM 52x, IBM P50 monitor, Samsung CDDVDW SH-202J and Win XP SP1. I have also tried to enable the DMA mode for the recorder via My Computer>Device Manager, but the problem still occured. I also use Free DVD Decrypter and terminate it while running several times (too long to wait). Could you please tell me why and the solution?
Thanks a lot.
R.S.V.P
				Results 1 to 1 of 1
  free software for burning data dvd in ISO (not UDF) file formatBy Toastie in forum MediaReplies: 3Last Post: 29th Oct 2010, 18:18
  How to Convert VOB file from DVD with ignore read errorsBy designbuyers in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:17
  svcd preview errors & vob file errorsBy kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 10th Nov 2008, 17:02
  VOB to DV last VOB file finishes in about one second w/no dataBy Gizmology in forum Newbie / General discussionsReplies: 3Last Post: 31st Jan 2008, 18:39
  How to pinpoint errors on a data CD?By nlec in forum MediaReplies: 10Last Post: 13th Sep 2007, 21:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
