I ripped a 2 hr movie to 700MB with credits 20% settings with AutoGK, final size got only 630MB and for 2 CD version i just got 1.26GB
Chosen Codec - XviD
Credits - 20%
Audio Type - I tried both VBR and CBR
Is it possible to get the desired size?
B.R.Vignesh
http://www.youtube.com/brvignesh -
Hi-
The problem could be caused by a couple of things. Please post one of the log files for the undersized encodes. -
What version are you running? Version 2.46 had a problem with undersized files which was fixed in version 2.47.
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
B.R.Vignesh
Are you using the XviD version bundled with AutoGK 2.48b? (XviD build downgraded to CVS 08/12/06 as in 2.40).
Using a newer version of XviD with AutoGK 2.48b can cause undersized files.
Then do another encode and post the log. Although you're using the right AutoGK (thus ruling out one of the ways to get undersized files), the XviD used and your AutoGK settings (file size and resolution, mostly) could easily play a role in determining whether or not you'll get the size you request. Also, when upgrading your AutoGK, it's better to first remove XviD via Add/Remove Programs, rather than installing over an already existing XviD. You might try that as well.Originally Posted by brvignesh
yes you're right, using the bundled version with the beta, i did re encode with latest XviD Codec i got the desired sizeOriginally Posted by drjtechB.R.Vignesh
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size differs from data size--HUH?!
By atoledo123 in forum MacReplies: 2Last Post: 9th Sep 2011, 13:19 -
Handbrake: Output picture size after conversion differs to source
By RF264 in forum DVD RippingReplies: 5Last Post: 11th Mar 2011, 07:02 -
How to rip dvd into small size mkv
By mazeer in forum DVD RippingReplies: 5Last Post: 5th Jan 2011, 15:05 -
Help in Final Cut Pro video size
By Sue Barker in forum MacReplies: 8Last Post: 25th Aug 2009, 09:51
