How do I prevent file splitting? Type-1 or type-2?
also set the discontinuity treshold [sic] to zero.
Type 1 or Type 2 depends on what you want to do with the file. TMPGEnc and VirtualDub and others use Type 2. The newer VDs can use either. Other programs may use one or the other. Check your program. There are file type changers available in our 'Tools' section that can change the type. The only real difference is in how the audio is combined with the video.
In WinDV, set the 'Discontinuity' to '0' and the 'Max AVI size (Frames)' to '100000' or max, and that should disable any splits.
Should I use WinDV?
By tygger in forum Capturing and VCRReplies: 19Last Post: 6th Jan 2012, 18:23 -
Windv to harddrive
By runnernorth in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2010, 05:36 -
WinDV Crash?
By phorkster in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 18Last Post: 18th Sep 2009, 13:32 -
How to configure windv?
By BonnieW88 in forum Capturing and VCRReplies: 3Last Post: 13th Sep 2009, 09:30 -
Error with WinDV ?
By Zhuge Liang in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Jul 2007, 03:47
