I have a PC with OS Windows 2000 Pro and a Pinnacle DC 10 Capture Card.
I intend to buy the Pinnacle Studio 11 Soft and install on this machine for using it to capture analog and digital videos but not HD video is it possible?
Would this configuration works?
I am asking because Pinnacle says minimum requirements is Win XP sp2 or Win Vista but I can´t install them on my machine without loosing a lot of other programs already installed.
>> Windows® XP with SP2 or Windows Vista™ operating system (32 bit Windows Vista recommended) <<
That's what Pinnacle says at their site. I would not take the risk to try it on Windows 2000.
There are also no official drivers for the DC10 for W2K and XP.
I know that Studio 9 can run on Windows 2000. Perhaps you can try to get an old Studio AV/DV package which has Studio 9 included and has capture hardware for DV and MJPEG.
I don't use Studio 9 but use the hardware with succes on W2K to capture mjpeg with VirtualDub.
Chris. -
Chris K
I used prior the Studio 9 on this machine with full success.
But I lost the CD soft and I cant reinstall the program.
Pinnacle is not selling anymore here these old softs.
Many Thanks for your answer!!! Lets see if somebody has ideas!
Making clearer I dont intend to edit HD Video!
Problems with Pinnacle Studio 9 using DC10+ Capture Card
By alexh110 in forum Capturing and VCRReplies: 0Last Post: 29th Jul 2011, 03:03 -
Pinnacle Transfer Capture card not recording footage of my N64?
By chibirobo1 in forum Video Streaming DownloadingReplies: 6Last Post: 28th Mar 2011, 21:03 -
MP20 Capture Card and Pinnacle Studio 14
By egee17 in forum Capturing and VCRReplies: 0Last Post: 26th Feb 2011, 19:30 -
Pinnacle AV DV capture card
By pawan.bishnoi@gmail.com in forum Capturing and VCRReplies: 0Last Post: 30th Jan 2011, 12:45 -
Unknown Pinnacle Capture Card
By Signal in forum Capturing and VCRReplies: 6Last Post: 24th Jul 2007, 19:03
