I have some NTSC DVDs purchased in Asia. THey are single-layer and supposedly region free already. However, when I put them in my Sony NS-315, I get the "Playback prohibited by area limitations" warning.
So I created an ISO file in DVD shrink, then re-burned to a new blank DVD+R.
Result? Same problem. This was also true whether I selected "Region free" or "Region 1".
I also chose "No Compression" and "Automatic" to see if that had any effect. It did not.
Is there a workaround to this?
Also, if this has been answered already, I would be happy with a link to other threads, and I apologize in advance for being too busy to search.
Cliff
Check the framerate of one of the VOBs. I suspect it's a PAL DVD 25fps not the NTSC. 29.97 or 23.976 Most DVD players use the same error for that as regional restrictions.
Otherwise, it would be odd that DVD Shrink wouldn't remove the regional restriction. You could also try DVD43 to overide the regional restriction. Or rip them first with DVDFab HD Decrypter.
I'd also try the burned DVDs on a different player. Maybe the Sony has a problem. -
Brilliant insight!Originally Posted by redwudz
Yes, it is really a PAL disc. My problem has been that all the players used in Thailand can play almost anything, so I was unable to determine that over there.
So I used DVDFab to get the info on the disc and yes, it's PAL.
Thanks for the rapid response too!
Issues getting DVD Shrink to work under Win7-64bit
By Djinn987 in forum DVD RippingReplies: 11Last Post: 30th Oct 2012, 17:44 -
Hello My dvd shrink 3.2 does not work anymore
By Seekyr in forum Newbie / General discussionsReplies: 1Last Post: 26th Apr 2009, 20:14 -
Region 2 DVD Work-around
By jackowens in forum Software PlayingReplies: 4Last Post: 25th Sep 2008, 10:16 -
Sony DVP-FX720 region restriction - using DivX waiting for region free code
By wig in forum DVD & Blu-ray PlayersReplies: 1Last Post: 27th Aug 2008, 05:34 -
work-arounds for nero alphabetizing mp3 files
By Mustang.VxD in forum AudioReplies: 6Last Post: 9th Jul 2007, 00:54
