Hello, I have a .VOB file with Dolby Digital 5.1 Surround Sound and I wanted to know which software I can use to author this file so I can keep the original audio without re-enconde.
Thanks,
dvdlab pro would be my choice.
If you don't need menus you can demux using vobedit and author using muxman, dvdauthorgui, guifordvdauthor or dvd styler. All free tools.
I believe the programs Baldrick mentioned can all do menus and chapters as well.
DVD Author
By Gunix in forum Authoring (DVD)Replies: 2Last Post: 30th Sep 2011, 03:48 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 11:10 -
Does Tmpg Divx Author encode or it only author ?
By BlackShadow90 in forum Authoring (DVD)Replies: 3Last Post: 29th Jul 2008, 03:56 -
Create DVD with TMPGEnc DVD Author 3 and not read on DVD Player
By Salutatous in forum Authoring (DVD)Replies: 1Last Post: 22nd May 2008, 10:22
