I have several avi files that I want to burn to dvd. I have also downloaded dvdflick, and I read the tutorial on here.
According to the tutorial, I added the first title (that is the first avi file) to dvdflick. Then I double clicked on the title name, went to the videos tab, and added the rest of the avi files and clicked accept. Then I clicked on project settings on the menu bar, and under the burning tab, I chose iso as output and then accept. Finally I clicked on start to start the process of making an iso file. But when dvdflick finished, there were just a bunch of m2v files in the specified forder but no iso file. Where did i go wrong?
What does the errorlog.txt file say?
Have you tried the latest beta version? -
where is the errorlog.txt file? anyways how can I burn all the avi files to a dvd? I am going to use dvddecryptor to burn the iso file to dvd, WHEN I get an iso file.
Are you making a DVD or burning AVI files? There's a big difference.
But since DVD Flick creates DVD files, you should have ended up with a VIDEO_TS folder with several files or a ISO container file of that same VIDEO_TS folder.
I wouldn't use DVD Decrypter for burning as it hasn't been updated in some time. ImgBurn is it's replacement. It can accept either a ISO or a VIDEO_TS folder for burning to DVD. -
Burn the files in NERO as data. Choose DVD, select DATA DVD then add the files .... no problem.
burning .avi and xvid files to DVD
By neviller in forum Video ConversionReplies: 3Last Post: 13th May 2009, 15:41 -
I have a question about burning avi files to dvd...
By amcardwell in forum Newbie / General discussionsReplies: 4Last Post: 22nd Apr 2008, 16:07 -
Problem Burning Some AVI Files
By Averc in forum Newbie / General discussionsReplies: 9Last Post: 8th Oct 2007, 11:33 -
Burning .avi files
By pilgrim02 in forum MacReplies: 13Last Post: 31st Jul 2007, 12:52 -
.avi files -- Help I'm burning lots of DVD blanks...
By TorreyGuy in forum MacReplies: 6Last Post: 11th Jul 2007, 08:58
