Hi,
i got a problem converting .avi to VCD (NTSC) with TMPGEnc-2.51.33.127. I always get a "stream writing error" at 58%.
Watching the .avi file on the PC works fine.
thanks
teqsun
Presumably you don't have this error on other input files so I guess that there is a corruption or perculiarity in this particular avi.
If the avi is a DivX file you may like to run a couple of "fix" programs on the file such as AviDefreezer (for frozen frame problems) or DivX Fix (for broken downloads)
I would also suggest you take a look at AviSynth (http://www.math.berkeley.edu/~benrg/avisynth.html) and open the avi through the program rather than letting TMPGEnc read the troublesome file directly.
Probelm with DVDx 4.0
By vevdare in forum DVD RippingReplies: 0Last Post: 13th Dec 2011, 23:57 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 16:42 -
probelm converting .mov to .avi
By Derrydoc in forum Video ConversionReplies: 3Last Post: 28th May 2011, 18:10 -
Synchronization Probelm with Dolby Digital EX Audio, Help!!
By caesarhawy in forum Authoring (DVD)Replies: 0Last Post: 23rd May 2009, 09:35 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07
