Is there a VGA to RCA cable, that's not HD15? The television I'm trying to hook up isn't HD. I'm just trying to go from my labtop to the TV.
Results 1 to 10 of 10
No, not with a cable. It would need a scan converter box. What other outputs are on this laptop? New ones have a "TV Port" Din connector with 4, 7 or 9 pins.Originally Posted by jason
4 Pin = S-Video. An adapter can be used to sum Y+C to composite.
7-9 Pin may include analog component YPbPr depending on the graphics chipset in the laptop. Consult your manual.
For Example my Compaq laptop with Nvidia Go 9100 chipset allows analog component over this 9 pin adapter.
http://www.kiva.org/about -
This labtop only has a VGA, and HDMI connector. It doesn't have the S-Video. Is there an HDMI to RCA?
HDMI is best. There is no HDMI to RCA. VGA to RCA needs a scan converter box.Originally Posted by jason
You need to consider getting a new TV.
What is the model number of this laptop?Recommends: Kiva.org - Loans that change lives.
No analog TV out.
Some VGA to Video converters
Low end
http://sewelldirect.com/pc-to-tv.asp
http://www.pinecomputer.com/pctovicaad.html
More
http://www.jr.com/JRProductPage.process?Product_Id=2013339&JRSource=yahoo.datafeed.AVR...ductTabDetails
http://www.clubit.com/product_detail.cfm?itemno=A9600230&cmp=OTC-yah00
Better
http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-vid.../prod9A60.html
http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-vid...prod40880.htmlRecommends: Kiva.org - Loans that change lives.
Displaying VGA on analog TV always look terrible.
You most likely won't get your money worth. -
Not always. VGA to an LCD-TV can look great.Originally Posted by SingSing
It all depends on the display card, the TV and if necessary the converter box.
I agree that unless you spend top dollar on a converter box, it will likely look terrible.Recommends: Kiva.org - Loans that change lives.
Connect laptop (VGA/S-video) to TV (RCA)
By indiannawaf in forum Newbie / General discussionsReplies: 20Last Post: 23rd Dec 2010, 06:48 -
Which is best way to do video out to TV with laptop VGA or HDMI to RCA?
By mjz55 in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2009, 06:15 -
VGA to RCA/S-Video HELP!
By eadavis in forum Newbie / General discussionsReplies: 6Last Post: 7th Apr 2009, 08:52 -
Weird Error - VGA to RCA
By HamishT in forum DVD & Blu-ray RecordersReplies: 5Last Post: 7th Mar 2009, 21:18 -
Laptop to TV using VGA and RCA?
By JediMoonShyne2 in forum Newbie / General discussionsReplies: 15Last Post: 9th Apr 2008, 16:51
