i have the romeo must die divx, and i used tmpg to turn it into a vcd compliant piece of material...but i dont think it worked right. when i went to put the converted copy into nero (newest version) it said it popped up that window sayin it wasnt vcd compliant. so i thought, "oh, welll it must be svcd then" do i loaded it up in the svcd window, nope, it said it wasnt svcd quality either. so here ill list the properties, yall tell me what i need to do. plz
Romeo must die :
640 x 304
1:1 aspect ratio
23,976 framers per sec
bitrate 1150000
1.316 mbit /sec
mpeg layer 2 audio
thanks for helping
first you really need to read what is VCD
http://www.vcdhelp.com/vcd.htm
640x304? VCD is 352x240
1:1 aspect ratio? 4:3
then you should also read the how to convert guides
http://www.vcdhelp.com/convert.htm
just incase you didn't see these links directly to the left
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 18:37 -
Beeping on vcd/svcd
By mgdt in forum Newbie / General discussionsReplies: 5Last Post: 20th Dec 2007, 10:56 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
How to copy-protect a VCD/SVCD v2.0
By Sine29 in forum User guidesReplies: 23Last Post: 20th Jul 2007, 10:27
