I've been having extreme problems with Premiere Pro 2.0 and Vista. I'm not sure if its either one, but I've never had so many problems with Premiere before.
When exporting a project longer than 15min. to an .avi file, I always get unknown errors stating that the drive is full, etc. I also have problems capturing video for long periods of time.
Has anyone else had problems with these? I'm thinking of installing XP.
breaking news is my life...
Premiere Pro 2 is not supported under Vista by Adobe ( http://www.adobe.com/support/products/pdfs/adobe_products_and_windows_vista.pdf ). Personally, I have never had a stable version of premiere under any OS, so it could be either, but more likely both.
What are your current computer specs ?
What format are you encoding your video to ?
Define a long capture ?
Are you writing to an internal or external drive when encoding or capturing ?
Have you installed Service Pack 1 for Vista yet ?Read my blog here.
Premiere Pro 2.0 is reported to be compatible with Vista here: http://www.iexbeta.com/wiki/index.php/Windows_Vista_Software_Compatibility_List#Video
But you should install it as 'Run as administrator'. -
thanks so much for your quick replys. i'm shocked! i'm currently running the adobe production/creative suite w/ premiere 2.0.
i edit on a eMachines...AMD X2 dual core processor, 2 gig ram, 160 gig internal, 500 gig external.
i don't understand the encoding question.
long capture...an hour.
i write too a 500 gig external drive.
i have installed the service pack 1 for vistabreaking news is my life... -
i have the same issue im using windows 2007 and its not letting me pull my premiere pro 2.o to cs3?
lsvtec,
I am not sure what Windows 2007 is. I am current running Premiere Pro 2.0 under Windows XP without any major problem.
Vista + W7 vs. XP Pro
By joecass in forum ComputerReplies: 17Last Post: 20th Aug 2010, 17:25 -
Correct settings for MPEG-4 AVC/H.264 for Premiere Pro 1.0 (Premiere 7.0)
By urpq32 in forum EditingReplies: 2Last Post: 24th May 2010, 05:22 -
Adobe Premiere Pro CS3 & Vegas Pro help
By KS89 in forum EditingReplies: 1Last Post: 8th Sep 2009, 23:52 -
SxS Pro card file MXF to DVD using Adobe Premiere Pro CS3
By Fary4u in forum Video ConversionReplies: 8Last Post: 20th Jul 2009, 10:00 -
logitech pro 9000 captured video to premiere pro CS3?
By yunakokimama in forum EditingReplies: 1Last Post: 15th Oct 2008, 17:27
