Results 1 to 10 of 10
    Apr 2008
    So I have this AVI file with 2 audio tracks, the first and default track is in French, the second one is in English.
    How do I go about deleting the French audio track and making the English track the default audio.
    Someone told me to get MediaInfo but can you really edit info with that? I though it was just to look at information.
    Thanks in advance
    Apr 2004
    Miskatonic U
    Open the avi file in Virtualdubmod. Click on Streams -> Streamlist. Click on the French audio track, then click on Disable (button). Making sure that both video and audio are set to Direct Stream Copy mode, save a new version of the file with only the English audio track (File -> Save AVI as)
    Read my blog here.
    USA
    Yes, MediaInfo or Gspot is just for information about the file. Depending on the video and audio format, you can probably use VirtualDub Mod to delete the unwanted audio track and save both the audio and video out in 'Direct stream copy' mode. That won't damage the original file as long as you use a different filename and it should only take a short time. VDM has guides on it's tool page, but this is a simple operation.
    And welcome to our forums.
    EDIT: Or what guns1inger said.
    Apr 2008
    Thanks guns1inger and redwudz.
    I'll be trying this out tomorrow.
    Glad to be part of Video Help. ^^
    Nov 2002
    You can use the newer versions of Virtualdub to do this also.
    Under Audio > Source Audio > choose Stream 2 and Direct Stream Copy both the Audio and Video.
    You can click on each audio and hit play to see what the audio is. In .divx files there can be all kinds of audio like directors cuts and extras.
    Apr 2008
    Well Just came back from finishing what guns1inger told me to do and it worked.
    It was so easy and simple to do, thank you very much for the help.
    Thanks DarrellS, I'll keep in that mind.
    Now I have a lot of reading to do on this forum :P
  7. Mod Neophyte redwudz's Avatar
    USA
    Glad it worked out for you. If you deal with AVI type files, get to know VirtualDub. It has many functions such as editing, encoding, capturing, filtering, frameserving and others. And there are lots of guides available, some on the tool page for the program. Well worth learning.
    Apr 2008
    People also use VirtualDub to make GIFs correct?
  9. Mod Neophyte redwudz's Avatar
    USA
    You can use it for making animated gifs, similar to the avatar I'm using. Just a short series of pictures that repeat. One tutorial: http://www.inat.org/page4.html
    Nov 2002
    All the animated gifs that I create with Virtualdub are corrupted but if I open them with Gif Movie Gear and resave, they're all good.
    The UnFREEz program seems to be OK for a free program. I like Gif Movie Gear for it's abilty to make AVIs from GIFs and GIFs from AVIs EDIT: and AVIs from Photoshop PSD files or other images.
