Hi.
I've searched the guides but haven't found anything that particularly deals with my request.
When I shoot film with my digital camera I got avi files that are sort of uncompressed. Each minute takes about 100MB.
I wonder what's the best way just to shrink them in size with the least quality loss?
- Program?
- Format?
I've tried Avidemux which is competent enough but maybe a bit to complex for my simple task.
Or maybe Avidemux is the one to use, but what's the best procedure in that case?
Also, is there any golden rule what size/minute a video should be in to be suitable for web before it starts crackin up completely?
thanks in advance!
:: nook
Can you provide more information such as the type of camera and, if you know it, the type of video that it exports?
John Miller -
I would use windows media or flash h264 for the web. You can make Windows Media using Windows Media Encoder or Windows Movie Maker. I don't know any free flash h264 video converters.
Thanks for your replies.
I'd rather not use wmf-format though since I want it to work on all platforms.
The camera is a Canon Ixus 950.
This is what Avidemux sais about the movie.
VIDEO
Codec 4CC: MJPG
Image Size: 640 x 480
Frame Rate: 30 fps
AUDIO
Codec: PCM
Channels: Mono
Bitrate: 88200 Bps / 705 kbps
Variable Bitrate: No
Frequency: 44100 Hz
How do I change the frame rate? I tried that in Avidemux but then it simply played the movie slower which got the audio out of sync. I guess I need to process the frame rate change somehow?
cheers :: nook -
You don't really want to change the framerate unless you like jerky looking video. For the web you might start by resizing down to 320 x 240. I would second Windows Media Encoder if web serving is your aim.
Read my blog here.
Originally Posted by nook
For web distribution, the leading choices are wmv or flash.
For DVD you would use MPeg2 video + AC3 or MP2 audio. Another option is Divx/Xvid for specific players.
For embedding in multi-platform applications the choices are many depending on context.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
How to convert MOV files created by a Kodak digital camera
By peliopoulos in forum User guidesReplies: 19Last Post: 21st Sep 2012, 10:31 -
Convert AVI from digital camera to what format
By hemang in forum Video ConversionReplies: 14Last Post: 24th May 2008, 07:13 -
is there a way to save at a Smaller size avi
By gilnan in forum EditingReplies: 3Last Post: 7th Apr 2008, 15:37 -
Digital camera video with 'CCITT u-law' audio?! How can I convert to XVid?!
By Emanef in forum Video ConversionReplies: 0Last Post: 31st Jan 2008, 09:28 -
Avi -> Smaller size
By gamerinha in forum Newbie / General discussionsReplies: 6Last Post: 27th Jun 2007, 11:29
