Hello
I downloaded a couple of movies in mkv format and I am trying to put spanish subitles.
I downloaded the spanish subtitles srt file from subtitles.org
I have been trying to use mkvmerge GUI whic seems a pretty straight forward, I just add the subtitles track and then Start Muxing into a new mkv file with a different name, I do not get any warnings or error messages, the program finishes doing it work.
But when I play the movie, the spanish subtitles do not appear.
Please I would kindly ask for any help
Best Regards
Patricio
What media player are you using?
Do you have directvobsub installed? If you do, just right click the icon and it should display a list of subtitles
You might have to rename the .srt file to the same name as the movie file before including in the .mkv file -
Poisondeathray, I tried Windows Media Player and VLC Media player, neither showed the spanish subtitles.Originally Posted by poisondeathray
Followed your advice, renamed thr .srt file and installed directvobsub. With VLC Media player I finnally could see the subtitles after the right click thing.
Funny thing is that after installing directvobsub I could no longer play the mkv file with Windows Media Plater.
Thanks for your help.
How to put new audio track to MKV file??
By golafs in forum EditingReplies: 1Last Post: 21st Nov 2011, 04:19 -
Once I put an MKV thru multiAVCHD the subtitles are lost
By mahogany in forum SubtitleReplies: 4Last Post: 8th Oct 2011, 15:49 -
How to put subtitles in a m2ts file ?
By sn0wer in forum MacReplies: 4Last Post: 18th Mar 2010, 11:52 -
Burning .mkv file with .ass subtitles to DVD WITH the subtitles
By isfjinfj in forum Authoring (DVD)Replies: 2Last Post: 23rd Jun 2009, 17:28 -
Possible to transfer subtitles from MKV HD file to converted MpegII file?
By peggypwr1 in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 10:58
