I have some files for one movie that are split into 2 folders, Disc1 and Disc2. The whole movie can fit on one DVD (not sure why there are 2 folders), but both sets have in the VIDEO_TS folder:
VIDEO_TS.BUP
VIDEO_TS.IFO
VTS_01_0.BUP
VTS_01_0.ISO
VTS_01_0.VOB (the Disc2 folder doesn't have this one only)
VTS_01_1.VOB
VTS_01_2.VOB
VTS_01_3.VOB
Is there a way to put them in order onto one DVD? Nero tells me that I can't have 2 files with the same name, and I'm not sure how and which files to rename if I can do that. I also read somewhere that you can only have 5 VOB files on a DVD, and I have a total of 7.
Thanks for any help you can provide! Never had this situation and trying to avoid too many coasters!
B
You can't just rename the files. You can use the free dvd shrink to join. See https://forum.videohelp.com/topic284279.html .
Actually, you shouldn't believe everything you read.I also read somewhere that you can only have 5 VOB files on a DVD...
Number of titles and VOBs = That makes about 1000 VOBs max per DVD.Up to 99(1-99) titles with max 10(0-9) VOB files each
For correct DVD information, see 'WHAT IS' DVD to the upper left on this page.
But VOBs are usually 1GB maximum, so the size of your media would dictate how many would fit, generally about 7 on DL media and 4 on single layer.
And welcome to our forums.
DvdStyler: multiple sets of menu buttons
By skaleton in forum Authoring (DVD)Replies: 16Last Post: 22nd Aug 2015, 04:09 -
Multiple title-sets share the same vob's
By kdolan1973 in forum SVCD2DVD & VOB2MPGReplies: 7Last Post: 17th Oct 2010, 18:52 -
multiple avi to vob
By matneaves in forum Authoring (DVD)Replies: 3Last Post: 20th Oct 2007, 18:47 -
VOB2MPG 0 Vob Sets Problem - wont work
By meno in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 15th Oct 2007, 21:36
