After shilly-shallying between use K-lite Codec Pack and Codec pack All In One and various of single codecs, a little anoying issue has appeared out of it thath im pretty used to, and that is..if choosing windows explorer to show icons as "summarize" the movie files shall originaly view as a black big square from side to side, alternate a preview of the first video frames..you know, this has disappeared perm on my computer and are now just the icon of the primary media player i use
So my question is, is there any known codecs thath generate this in combination with eatchother perhaps?, could it be registry remnant of old codecs on my computer that blocks the standard view?, cause i have restored this before but i hade lucky and don't remember what i did, i know i can fix it by just reinstall OS, but i wanna avoid it
Here is a living a example of what i mean, if you didnt understand the text (understandable)
Current perm-state on all videos
Wrong! (yes its really sett to summarize)
Wannabitch normal-state on all videos
Alternate like this (Preferable not..but)
Is there any solution?..(either than avoiding go to bed)
I'm assuming you are aware of the dangers of system damage from codec packs.
But if I understand what you are describing, first you need to have 'Thumbnails' view selected for your folder. And make sure to look in the 'Folder Options>View' settings to see if they are turned on there. It's probably easiest to just reset all folders to 'default'. If you do, you might want to uncheck 'Hide extensions for known file types' or you won't be able see all your extensions.
But if those settings are correct and they are still showing as blank and you have the proper codecs installed, you've got something wrong with Explorer. Not sure exactly what, but if it happens with all video formats, it may be something in the registry.
You can try re-enabling thumbnail previews by typing this into a command window: regsvr32 shmedia.dll This should reset the thumbnail function.
Information here: http://www.mydigitallife.info/2008/03/17/how-to-enable-or-disable-media-and-video-thum...in-windows-xp/ -
Thath command did the trick yes, nice to be able to choose self now, thank you redwudzOriginally Posted by redwudz
Question how to change icon of software icon
By jimdagys in forum ComputerReplies: 3Last Post: 10th Oct 2009, 04:47 -
Help D; Codec Sniper Entries/Registering Codecs/Broken Codecs
By Antischism in forum ComputerReplies: 0Last Post: 5th Nov 2008, 14:29 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 00:01 -
Vista Codecs - New PC Requirements - Are Codecs Needed
By doggyofone in forum Newbie / General discussionsReplies: 6Last Post: 30th Aug 2007, 19:52 -
Application to View Codecs that are Installed on Your System
By JBredensteiner in forum Newbie / General discussionsReplies: 4Last Post: 23rd May 2007, 00:58
