Hi,
I'm currently making a DVD compilation of sorts and I'm using TMPGenc DVD Author 3. I compiled them, maked the menu and stuff, and at the output I found out that the maximum size was only 9GB (my file size was 11 GB, and this was the first time that I reached that limit). I have DVD Shrink so I'm not really worried with fitting it in the DVD but are there other softwares that doesn't have this limit? Thanks!
Very few, if any. You are limited by the size of a physical disc. If you encode properly in the first place, rather than follow sloppy practice and use Shrink to fix the problem, you will get a better quality outcome.
You might try GUIForDVDAuthor, as I believe it might let you go over size, however it is still a poor method to follow.Read my blog here.
With DVD Author 1.6 you can ignore the warnings and make it any size you like.
I'm thinking that I did encode it properly, but its just that there are too many video that I'm cramming into a single disk
. I'll check the GUIforDVDAuthor and 1.6 too.
Thanks! -
If you encoded it properly it would have fit. regardless of how much you may be trying to cram onto the disc, or how low the quality might be because of it, if you use the right bitrate it will fit. if it doesn't fit, you did it wrong.
Secondly, if you are trying to fit too much on, the quality is already going to be questionable. Using a transcoder like Shrink to force it to fit is only going to reduce the quality further.
I get the feeling you haven't really thought this through.Read my blog here.
It seems that TMPGenc DVD Author 1.6 is also having an error in the 11GB size. Oh well, I'll try the GUIforDVDauthor and if it fails, I'll just have to cut back on those videos that I have.
What do you think??? Maximum Quality/Low File Size DVD conversion
By iqbal88 in forum DVD RippingReplies: 6Last Post: 7th Aug 2011, 03:48 -
Philips DVP 3360/05 - Maximum file size when using USB
By jeffdavies in forum Newbie / General discussionsReplies: 2Last Post: 9th Aug 2010, 05:31 -
TMPGEnc Maximum File Size for Authoring?
By cym in forum Authoring (DVD)Replies: 3Last Post: 26th May 2010, 02:55 -
TMPGEnc DVD Author file size too big issue
By silverwolf0 in forum Newbie / General discussionsReplies: 7Last Post: 25th Dec 2007, 18:53 -
Is there a maximum resolution or size for jpgs imported into Vegas 7?
By nzo in forum Newbie / General discussionsReplies: 2Last Post: 8th Oct 2007, 21:18
