hiya
i have an flv file,can someone plz convert it into an avi
plz dont give me the instructions how to do it,because i have no idea of understanding such issues.
however i´d highly appreciate it if someone can do it for me
http://www.moonshadeworld.net/redirector.php?url=http%3A%2F%2Frapidshare.com%2Ffiles%2...2Fkk.part2.rar
ps:in case it asks for an password its moonshadeworld.net
many thanks
Results 1 to 30 of 58
http://media-convert.com/ , choose your flv file and select audio video interleave(AVI) as output.
FLV Extract...
" Who needs Google, my wife knows everything" -
thnks for all the links,however can somebody plz do it for me.
the mediaconvert.com seems to be easy but my file isnt saved on my browser and i have no clue how to save it ,and i dont understand anything,some1 plz do it for me -
Not from that link. That is only one part of a multi part archive.Originally Posted by lóreal
RAR files are archive files crated by WinRAR. Archive files usually contain one or more files compressed to make them more portable (smaller for uploading and downloading).
The file you linked to was one part of a multipart archive. You need all parts in order to extract the FLV file that's inside them. -
http://www.moonshadeworld.net/redirector.php?url=http%3A%2F%2Frapidshare.com%2Ffiles%2...2Fkk.part1.rar
password:moonshadeworld.net
so here are all parts of the RAR file
plz try again -
Those two links were sufficient to get the entire archive. There are two FLV videos inside. About 10 minutes each.
Well I'm not impressed with Media-convert.com. I directed to convert an flv from youtube into avi and the resulting file had nothing but static for audio and poorer quality video than the flv.
I have a freeware program called atube, available from http://ytc.dsnetwb.com/atube_software_forEx/ which is supposed to be able to convert flv to other formats but I don't seem to have the right codec to make it work...
What are some other options for flv conversion? -
Vixy online did a horrible job. No sound and pixelated washed out video.
I've only used it a few times to convert short clips to Divx AVI but worked fine for me. Maybe your graphics card's video overlay needs to be adjusted?Originally Posted by Clydesdale
Obviously, for the best results you should download the FLV and do your own conversion. But if you don't want to learn how to do conversions vixy.net is ok.
I've done many conversions over the years. Flv is the new element here...
Virtualdub doesn't even recognize an flv file.
Avidemux makes a nice quality mpeg conversion but with no audio. The various selections for video and audio are less than clear. At a minimum I'd like to be able to extract audio from the flv....... -
What's used syntax?Originally Posted by Clydesdale
VirtualDub with FLV input plugin can open FLV's.Originally Posted by Clydesdale
Odd...Originally Posted by Clydesdale
What's config?
Of course You choose MPEG-PS (A+V), not just MPEG video?
If FLV contain MP3 audio... FLV Extract (or FFmpeg, MPlayer/MEncoder, Avidemux, VirtualDub with FLV input plugin).Originally Posted by Clydesdale
If FLV contain other audio (Nellymoser or ADPCM)... required recompression, example used FFmpeg. -
ok here's the settings I used with avidemux:
Video DVD (lavc)
Audio AC3 (lavc)
Resampling 48000 khz
Format MPEG-PS
Resulting mpeg has audio but way out of sync with video
I also tried:
Video Mpeg 4 ASP (Xvid 4)
Audio mp3 (lame)
Format AVI
Again audio is out of sync.
I got the virtualdub flv plugin and was able to load the file but when trying to save to avi I got a codec error (codec cannot decompress to an RGB format).
Use FLV Extract and look at True Frame Rate and Average Frame Rate.Originally Posted by Clydesdale
If different... FLV have VFR (variable frame rate).
(Possible exceptions...)
Avidemux and VirtualDub not support variable frame rate.
If video have VFR, good solution is use Avisynth script (with set source FPS and used ConvertFPS) or eventually FFmpeg.
You choose and configure video codec? Example Xvid?Originally Posted by Clydesdale
BTW
Look 'around'... many similar topics is on this and other forums. -
Not really familiar with this software. I had audio at direct stream copy and video at full processing. Then chose File/Save as AVI. What codec do I need to make this work? -
Ok it does have different values for average and true frame rate in flv extract. I dont understand your reference to avisynth... -
If You have set Full processing mode, then go to Compression... - choose video codec and configuration (bitrate, ... ).Originally Posted by Clydesdale
It's Your choice. Example Xvid or DivX.Originally Posted by Clydesdale
Of course first - You must have installed this codec (in system).
Well, it's probably VFR.Originally Posted by Clydesdale
To avoid 'out of sync' (if source have VFR).Originally Posted by Clydesdale
Install Avisynth (if not installed).
Write simple script (example in Notepad) and save with .avs extension.
FPS= set true frame rate (after check used FLV Extract)Code:DirectShowSource("C:\path\name_file.flv",FPS=29.97, ConvertFPS=true)
Open .avs file in VirtualDub, choose and configure audio and video codecs, save/recompress to AVI.
If You try FFmpeg... with what syntax? What's used codecs, bitrate, ...?
Remux FLV (AVI and MP3) to AVI without VFW?
By vbug in forum Video ConversionReplies: 2Last Post: 26th Mar 2010, 12:32 -
.FLV vs. .AVI
By coody in forum Authoring (DVD)Replies: 8Last Post: 19th Mar 2010, 20:20 -
Movie Clip Will Not Convert from .flv to .avi - Pazera Free FLV to AVI
By videoelfone in forum Video ConversionReplies: 3Last Post: 21st Jun 2008, 00:14 -
Problem with artifacts in flv conversion - i.e. converting to flv from avi
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 30th Apr 2008, 22:09 -
Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?
By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 22:11
