Hi,
I have a couple of AVIs with resolution 800x432. I am going to resize them to 720 so that they can be played on DVD(DivX) player. What is the best way to resize it? Should I keep aspect e.g. 720x389? or I can resize to 720x432? Which one will keep original quality?
Wu
The resize filter in the newer versions of Virtualdub will figure the resolution for you.
Once you get your figure of 720X388.8 you'll need to tick disabled under aspect ratio and change 388.8 to 388 since 720X389 is not a valid resolution. 720X432 will make everyone too tall. -
Are you sure you have to resize them?
I have a DivX compatible media player that accepts many AVI dimensions and just resizes the display automatically. Granted it's not a DVD player but I think it uses the same Sigma chip for processing
If you are re-encoding with a lossy codec (such as DivX or XviD) none will keep original quality
Resizing video resolution and video quality
By Timex in forum Video ConversionReplies: 13Last Post: 23rd Aug 2011, 22:08 -
old way of resizing mp4 with little loss of time & quality
By visible0 in forum Video ConversionReplies: 0Last Post: 15th Apr 2011, 00:13 -
Convert .vob to another format with max quality
By alexv305 in forum DVD RippingReplies: 7Last Post: 19th Jun 2010, 22:36 -
Max DivX quality in DVD player, please!
By zovx in forum DVD & Blu-ray PlayersReplies: 6Last Post: 7th Feb 2010, 12:43 -
Best way to convert a video to iPod with max quality and min filesize
By Salva Veritate in forum Video ConversionReplies: 1Last Post: 4th Jan 2008, 10:34
