Hi All,
Can someone please tell me why there are 3 identical large files in the video folder on a DVD? Do what do they contain? They all seem to have the same vob video file within. are they combined in some way when the video is rendered?
confused
Brian in ireland
When you author a DVD, all the audio, video, subtitles, menus etc are put into a structure that uses the VOB container for storage. However a single VOB may not be larger than 1000MB is size, so if a movie is larger than that (and most are), you will get multiple VOB files. If you look at a commercial DVD for something like Godfather II you will find that the main movie spans around 8 VOBs.
Read my blog here.
You can also look to the upper left on this page for 'WHAT IS' DVD to see the DVD structure, format and specifications. It will tell you what each part of a VIDEO_TS folder is and what's in it.
And welcome to our forums.
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Is it doable to convert HDV/.m2t 1080i files to AVI files and what...
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 4Last Post: 30th Sep 2007, 04:03 -
whats best to use to copy my home videos to DVD... avi files or wmv files??
By leegutcher in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2007, 04:24
